Tube op amps
Tube op amps
Old 14th October 2005, 12:20 AM   #11
bear is offline bear
expert in tautology
bear's Avatar
Tube op amps
I've got a NIB Philbrick Opamp sitting here...
oh boy!
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 14th October 2005, 12:37 AM   #12
On Hiatus
SY's Avatar
Tube op amps
Originally posted by Devius
I have a doubt...
I've read the article on headwize regarding tube opamps, and I recall reading somewhere (maybe in this forum) that the usage of negative feedback in tube designs reduced the gap to solid-state designs in terms of sound. So, if I were to use one of those tube opamp designs configured for a gain of 10dB, or something like that, as a line stage would I lose the benefits of using tubes in the first place?
In the sense that you'll have lower distortion and source impedance, yes, it will sound closer to good solid state.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 14th October 2005, 01:25 AM   #13
Sheldon is offline Sheldon  United States
Devious opens:
"I've read the article on headwize regarding tube opamps, and I recall reading somewhere (maybe in this forum) that the usage of negative feedback in tube designs reduced the gap to solid-state designs in terms of sound. So, if I were to use one of those tube opamp designs configured for a gain of 10dB, or something like that, as a line stage would I lose the benefits of using tubes in the first place?"
SY counters:
"In the sense that you'll have lower distortion and source impedance, yes, it will sound closer to good solid state."
audio aikido?
Old 14th October 2005, 02:01 AM   #14
On Hiatus
SY's Avatar
Tube op amps
OK, how about this? "In the sense that you'll have lower distortion and source impedance, it will sound closer to my cathode follower preamp."
Old 14th October 2005, 04:25 AM   #15
Sure, as long as you remember that I have no clue on the merits. I just thought i detected some clever irony. My lame attempt acknowledge the effort.
Sheldon
Old 14th October 2005, 04:23 PM   #16
Devius is offline Devius  Portugal
SY:
So I guess you're saying it should give good results. I was interested in those tube opamp designs since they allow lower gains to be set more easily without changing tubes.
Old 14th October 2005, 05:17 PM   #17
On Hiatus
SY's Avatar
Tube op amps
Well, the nice thing is that all the tricks for compensating them for low gains are well-known. This wouldn't be my first choice for a from-scratch design, but I wouldn't argue with someone who decided to go that route.
Tube op ampsHide this!Advertise here!
For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! opc Swap Meet 23 2nd November 2009 05:04 PM
Help Please with tube amps!!!!! bobcat1979 Instruments and Amps 1 28th June 2009 11:29 AM
Which One Of These Tube Amps Should I Buy? dantwomey Tubes / Valves 14 5th June 2007 02:07 AM
These are the best looking tube amps I have ever seen A3rd.Zero Tubes / Valves 21 30th April 2004 03:22 AM
Tube amps.......AGAIN Brap Tubes / Valves 7 22nd January 2004 04:07 PM
