diyAudio Sponsor
Old 10th October 2005, 04:05 PM   #1
philipbarrett's Avatar
Send a message via AIM to philipbarrett
Default 3rd Aikido?
Well, since I managed to miss both the 1st & 2nd, I'm hoping there are enough of us procrastinators out here to justify a 3rd run? If so, please count me in for a PCB & a PSU.
Thanks, PB
Old 10th October 2005, 04:10 PM   #2
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Hi Phillip,
If the octal board works out we will have about 8 of those. (If you are interested in the octal version) And I have some PSU boards left...
And don't forget John Broskie should come out with his boards any day now :-D
So it seems no matter what you'll be able to get some boards soon
Bas
Old 10th October 2005, 08:19 PM   #3
Hi Bas
are 4 pieces of octal version available?
jacques
Old 10th October 2005, 08:39 PM   #4
Hallo Jacques,
As soon as I have tested the boards there will be 4 available.
Mmm that is all the octals sold out already.
Bas
Old 10th October 2005, 11:29 PM   #5
Bas,
Have I missed the octals? If by chance there are some left I would be interested.
Thanks,
Joe
Old 10th October 2005, 11:44 PM   #6
Hi Bas
did you make some listening tests between the novals (I guess 6N1P and 5687) and the octals (all other parts beeing the same)
I have plenty of 6SN7-VT231-B36-12SX7 plus 6BL7 and 6BX7 to compare with the 6N1P-6N6/6N30 tandem...
I just have to buy the sockets for the PCBs (have plenty for chassis mounting, just missing those for PCBs )
kind regards
jacques
Old 11th October 2005, 06:35 PM   #7
I would be interested in octal boards also..
Dave
PS: Bas the boards from the first order arrived safe and sound, thanks.
Use 9 pin Aikido PCB kit or buy 8 pin ? Renron Tubes / Valves 6 25th November 2007 04:52 PM
JB Aikido Pre 9 pin kit Renron Swap Meet 1 20th November 2007 07:51 PM
New PSU for Aikido? cbutterworth Tubes / Valves 5 6th September 2007 01:03 AM
Aikido HiFiNutNut Swap Meet 1 24th January 2007 04:26 AM
Aikido PSU help cbutterworth Tubes / Valves 48 13th October 2006 07:54 PM
Page generated in 0.11736 seconds (62.81% PHP - 37.19% MySQL) with 10 queries
