| diyAudio Sponsor | ||
Hi amperex,
In this post http://www.diyaudio.com/forums/showt...750#post707750 you give instructions for modifying a Hammond organ chassis to make a triode 6V6 push pull. It piqued my interest but after hours of dizzying boredom sifting through Hammond schematics, tribute sites and Ebay I can't find a chassis that exactly matches your description. Most organ amps with a quad of 6V6s are biamp models with separate (and differently part numbered) bass and treble output transformers. The one or two found which are true full range didn't have a 6J5 front end, at least not on the same chassis. Either the description doesn't match or I can't see how they're adaptable to full range use. Could I trouble you for a little more detail? Thx in advance. |
#2 |
Here is a picture of my amps. The audio transformer is different as well as the tube line-up. I used 4x 7C5 (same as 6V6) plus a 6CG7 splitter/driver.
#3 |
Thanks amperex, now I have something to look for.
#4 |
The choke in the stock amp are both the same size. I replaced one stock choke with a physically smaller choke next to the power transformer. I wanted a higher DCR as voltage was a little too high for 6V6 triode connected. The stock audio transformer sits in the chassis like the power transformer. All chassis of this type are black wrinkle paint. I find these amps on ebay.
#5 |
Thx again. You mean like this one?
http://cgi.ebay.ca/JENSEN-HAMMOND-TU...QQcmdZViewItem Judging by the 'buy now' on this auction word may be out. |
#6 |
Yes, that is it. Only, I paid about $60-70 each. $300 is way out of line.
#7 |
You wouldn't happen to have a link to the schematics? If it's similar to the some other Hammonds I saw it looks like an interesting circuit to play with.
#8 |
I just look at the wiring on the tube sockets & associated parts. A schematic kind of forms in my head as I have many tube sockets & various circuits memorized.
| Anyone heard of Fisfar organs? | Test Electrix | Instruments and Amps | 5 | 9th July 2009 07:07 PM |
| overdrive circuit for hammond organs(need help) | shwaggety | Tubes / Valves | 0 | 15th August 2008 09:44 AM |
| Which Amperex ECC88 is the best? | ac2005 | Tubes / Valves | 1 | 7th September 2005 03:04 PM |
| Amperex 6DJ8 | hifiZen | Tubes / Valves | 8 | 10th July 2004 08:13 AM |
| IB gurus: Tempest vs. BPD 1503 for organs and explosions | VDoran | Subwoofers | 2 | 8th January 2002 05:13 PM |
| Page generated in 0.13492 seconds (59.06% PHP - 40.94% MySQL) with 11 queries |
