Best amplifier (recomendations) for Fostex FE108ez?
Old 30th September 2005, 10:28 PM   #1
Guijs is offline Guijs  Brazil
Default Best amplifier (recomendations) for Fostex FE108ez?
Hello,
I have built a pair of BLH for Fostex FE108ez. I'll order a custom tube amplifier for them, and i'd like to know wich are the most used amplifiers for these speakers. Can you guys gime some project recomendations? Waht power do you recommend for these loudspeakers?
Guilherme
Old 1st October 2005, 06:33 PM   #2
amperex is offline amperex  United States
Default I'll stick my neck out.......
Although never heard this amp on your speakers, the Transcendent Sound T16 has outperformed a few highly regarded 45 type tube amps on some highly regarded speakers.
This amp is neutral sounding and will disappear in the audio chain. If one wants that SET amp with some 'color' added in the midrange (often called SET magic) and 'softer' bass, buy a SET design. The T16 is noted for being very fast & detailed. This can cause poor recordings to sound exactly as recorded- poor.
I believe the amp outputs 15-watts per channel. Cost is $1199 as a kit or $1699 assembled. The amp requires a preamp.
Old 1st October 2005, 09:19 PM   #3
doorman is offline doorman  Canada
doorman's Avatar
I'm running my modded Buschorn's (w/FE108EZ's) with a Decware Zen SE84CS, 2wpc SET. Very open and dynamic combination, plenty loud enough (pour moi!). Their 6wpc SEP, would also be a great combination IMHO. www.decware.com
Old 2nd October 2005, 02:44 AM   #4
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Re: I'll stick my neck out.......
That is a facinating amp. We (ie Chris) had good luck with his (frugal-phile(tm)) EL84 SE parafeed monobloks (in both triode and in RH mode)
The Bottlehead Paramours also worked well.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd October 2005, 06:38 AM   #5
hagtech is offline hagtech
hagtech's Avatar
Check out the Horn Shoppe site. Ed has some recommendations for amplifiers. Many users seem to like the F1. I've been trying to get him interested in a pair of Cymbals, but he's quite happy at the moment.
http://www.thehornshoppe.com/
jh
Best amplifier (recomendations) for Fostex FE108ez?Hide this!Advertise here!
NIB 2 X Fostex FE108EZ FREE ship USA dhenryp Swap Meet 2 12th July 2009 07:26 PM
Fostex FE108ez Sigma vs Creative Sounds WR125 Guijs Full Range 6 21st April 2006 09:56 PM
Fostex recommended FE108EZ back loaded horns hkoetz Swap Meet 0 15th March 2005 07:51 PM
Fostex FE108EZ recommended enclosure hkoetz Full Range 3 23rd November 2003 12:42 PM
fostex FX120 or FE108EZ ? ( was : need help fullrange project) punk Multi-Way 0 11th March 2003 01:43 AM
Copyright ©1999-2017 diyAudio
