| diyAudio Sponsor | ||
Howdy folks, got a question about using ohm's law:
Schematic for my 7591 PP amp calls for 480v on the plates. I'm getting 520v-ouch! I've got high line voltage to my residence and I know the power xfrmr is putting out @840v CT rather than 800v CT. Right now the situation is a pair of dropping resistors for each channel. 200ohm, 10 watt. Voltage before the resistor is 540. Voltage drop after the resistor is now 520-but I need 480. If I did the math right, I need a 600ohm 10w resistor to bring the voltage down to 480-is that right? If anyone could jump in and help quick I'd appreciate it-I'm gonna try and make a break from the office this afternoon to get the resistors-if I don't get them today I'll have to wait till Monday which means no music over the weekend. Cant have that! Thanks for any and all help mr mojo |
#2 |
Your math is correct.
Currently there is a 20V drop over a 200Ohm resistor. The current throught the resistor is 100mA. For 60V drop you need indeed 600Ohm. BUT... the power dissipated in this resistor will be 6 W (600 V * 0,1 *0,1). A 10W resistor will become quite hot. You could try and put 2 1k2 10W resistors in parallel.
J-amp powers Avantgarde-Acoustic Trio |
#3 |
You are withing 10% of the voltage so I personally would not worry about it. I have an EL34 amp thats supposed to run at 480V on the plates and its 525V measured. Been like that for about 5 years.
If you really want to drop the voltage and you have a pi filter you could try a smaller uF value irst capacitor instead. Andrew
None of us are leaving this world alive. Enjoy it responsibly as you may. |
#4 |
Wowee!!
You guys ROCK-thanks for the quick replies. Andrew, I'm not so concerned about the plates-it's the 500v electrolytic filters on the output transformers that concerns me! Yow. At least I know the Spragues will handle a bit more than their rated voltage-but for how long is anybody's guess. My guess would be not long. dutch, Thanks for backing me up on my math-I'm gonna go with either a 560ohm 25w or a 680ohm 25w. That's as close as I can get to 600 and the 25w rating should handle the power better. I appreciate the help-I really do. I know enough to be dangerous-but heck, that's half the fun. Best, mr mojo |
#5 | |
Your math is right but I don't think it matters. For a tube circuit you are practically dead on. With voltages pretty much anything within 10-15% is fine. Remember tubes were designed when 10-20% resistors, 20% capacitors and fluctuating line voltages were the norm.
--Sherman |
| Fast Class A Amp | Nico Ras | Solid State | 58 | 11th January 2009 09:22 PM |
| THAT was fast | DragonMaster | Everything Else | 0 | 25th August 2006 05:52 PM |
| help fast ! | v1d9uy | Full Range | 3 | 12th January 2006 10:15 PM |
| i need fast help | shereen | Digital Source | 0 | 21st June 2005 09:14 PM |
| How fast are 'Fast Fuse' and how to identify? | bigpanda | Solid State | 7 | 22nd March 2005 09:00 PM |
| Page generated in 0.11063 seconds (64.01% PHP - 35.99% MySQL) with 10 queries |
