| diyAudio Sponsor | ||
Finnaly i got around to building RJM simple tube phono pre.
http://www.geocities.com/rjm003.geo/.../diy_pho1.html Not a high end project. But i thought it is a good start for me. (never build a tube amp before) It sounds very nice i have to say. Not bad at all. I do have some hum but thats do to the grounding and no shielding. But gone build a nice case for it. It's worth it.
Music is what i want, music is what i need |
#2 |
Replace that half-wave rectifier with a bridge rectifier! It will certainly help your hum. Half-wave rectification is doubleplus ungood.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#3 | |
I think it hums because i didn't make a ground star. It's just a test set up. I'll try later today to improve the grounding. And see where that leads me.
| DIY phono preamp - cheap and simple! | rjm | Analogue Source | 426 | 16th March 2012 09:58 AM |
| Low-V simple phono stage + tube buffer | ikoflexer | Analog Line Level | 0 | 12th October 2008 12:45 PM |
| Simple phono stage (MC) | Onvinyl | Analog Line Level | 5 | 9th August 2008 09:50 PM |
| Simple tube phono stage | ambience exists | Tubes / Valves | 8 | 27th June 2008 02:29 AM |
| Page generated in 0.07468 seconds (74.51% PHP - 25.49% MySQL) with 11 queries |
