diyAudio Sponsor
Old 28th September 2005, 11:04 AM   #1
gongken is offline gongken  Sweden
Default PWM amplifier hooked onto a tube preamp
Hi!
I´m about to build myself a guitaramp. The philosophy is to use a tube preamp (for good distortion) and hook a Class-d power amp onto that, say for an example an UcD-180...
The preamp schematic looks someting like this
How would a class-d amplifier reakt to being hooked onto a preamp like this?
What about the output impedance of the preamp, how would it interact with a PWM amp???
Any general tips or hints on the schematic?
I´m not really good at this so i'm thankful for all support, and I
would humbly ask ypu to keep a modest technical level of your answears so I can understand you folks
This topic can also be found in the "Class-D" section.
Kind regards
Andreas
A white Volvo turns into the Ringroad
Old 28th September 2005, 11:16 AM   #2
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
I think you will need a cathode follower added to the output in order to drive the low input impedance of a solid state amplifier. The input of a switching ampliier is almost certainly an op-amp, but it will probably have quite a low value shunt resistor (10k is likely). Some Tripath switching amplifiers are configured to be inverting amplifiers and are supplied 49.9k input resistance.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 28th September 2005, 02:25 PM   #3
So, I've herad that it's possible to build a little input buffer for the PWM with an OP-amp to ensure that the output impedance is kept low of the tube preamp. I've seen an article i think, but i can't remember where...
Can anyone please make a drawing of such a schematic??
Kind regards
Andreas
Class D amplifier with tube preamp on input any ideas jazzman06 Class D 9 4th July 2009 11:44 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps MartyM Tubes / Valves 3 16th October 2008 04:52 AM
Finally have my DC300a hooked up !! thermal runaway Solid State 8 2nd February 2008 02:56 PM
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 15 24th November 2005 01:19 AM
Class-D poweramp hooked on a guitar tube preamp, questions gongken Class D 13 2nd October 2005 03:06 PM
Page generated in 0.06303 seconds (73.52% PHP - 26.48% MySQL) with 10 queries
