Check my first design, 6900/2A3 IT
Old 30th October 2002, 02:30 PM   #51
Joel is offline Joel  United States
Joel's Avatar
Default build it your way then... I don't care.
aaron,
I'm not suggesting you skimp, or build a "cheap" amplifier, or compromise in any way. That would be absurd. I'm merely suggesting you use the right tool for the job. There is no prize for building the most expensive amp, and money does not gaurantee good sound - although you seem to be equating the two.
I was just trying to help offer a viable alternative. And I think $550 for a SET power supply is a lot of money. Sorry if pointing that out annoyed you.
Finally, I would just add that I have PSUD installed on my computer - and it does not perfectly model reality.
Old 30th October 2002, 02:32 PM   #52
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Check my first design, 6900/2A3 IT Send a message via AIM to Peter Daniel
Originally posted by Joel
There was a guy in another section of the forum that claims he hears a difference when he places 3 cd's on top of his player, as opposed to only 2 cd's. I'm not kidding. I will not keep an open mind about that.
I could hear the difference when I placed 5 CD jewel boxes on my player as opposed to nothing on top of the player, no kidding. I'm not sure if this smilie is not reserved for moderators use only
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 30th October 2002, 02:39 PM   #53
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default RATTLE AND HUM
Hi guys,
Hmmm,five rattle a bit more than two,right?
Relax,fellows!
Frank
Old 30th October 2002, 02:57 PM   #54
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Have you tried placing random items from around the house on top of your cd player to see if you can get it to sound better? A friend of mine has a cat that likes to sit on top of his cd player... I wonder how that effects the sound.
Brian
Old 30th October 2002, 03:21 PM   #55
Here are some descriptions of my experimenting with a player. When I checked it now, it's indeed 3 boxes and not 5. Joel must have been talking about me.
http://www.diyaudio.com/forums/showt...s&pagenumber=4
www.audiosector.com
Old 30th October 2002, 03:27 PM   #56
Joel's Avatar
Was that you Peter??? Haha, sorry for making an example out of you - it just struck me as amusing.
I have learned to place my dog on top of mine. The 100Hz region seems more warm and "wooly" now.
Old 30th October 2002, 05:16 PM   #57
arnach is offline arnach  United States
Send a message via AIM to arnach
Well, this whole tube amp DIY thing for me started out with the Baby Ongaku, and it was Gordon Rankin who sent me the initial power supply schematic with two chokes, and I trust his ears :-)
The total is costing far too much, but I think it's worth it..
Power supply $550 (Tango MX-175, LC-10-200, LC-15-150)
Interstages $264 (Tango NC-14)
Capacitors $180 (all Solen)
Resistors $50 (Audio Note)
Tubes $200 (6900 pr, Sovtek 2A3, Mullard 5AR4)
Output Trannys $600 (Tribute amorphous)
around $2k for the project. :-( .. But alot of the cost is getting some of those components from Japan, for instance, the power supply is only really US $380.
Getting real african ebony wood pieces for the chassis and copper plate.. but that's not for a while.
No complaints with the Tango NC-14?
Old 30th October 2002, 05:27 PM   #58
Here are the simulation of my PSU (bottom) versus Joels (top). I do believe mine is worth the extra money.
Please keep in mind the following qoute from Joel: "Finally, I would just add that I have PSUD installed on my computer - and it does not perfectly model reality." .. Obviously this is true, but the differences are large enough that even a significant margin of error on the part of the simulation can be overlooked.
Finally, Joel, I wasn't annoyed, no worries :-)
Old 30th October 2002, 06:36 PM   #59
Joel's Avatar
Yes, the millivolt of ripple reduction is worth $400....
I stand by what I said - your power supply is overpriced, and overdesigned for this project.
Best of luck. I'm sure you'll be happy with your amp.
Old 30th October 2002, 06:50 PM   #60
Actually $140. Thanks.
Check my first design, 6900/2A3 ITHide this!Advertise here!
Harman Kardon HK-6900 ManUtd Solid State 7 14th August 2012 05:11 PM
PSU Design Check Please ANDYLASER Power Supplies 14 15th July 2010 11:42 AM
Got any Sansui au-6900 SM, schematics or whatever? taj Solid State 0 31st December 2008 11:16 PM
New Here. Will you check me design? SightSeeker1 Subwoofers 19 13th April 2006 03:59 PM
5687/6900 spice model tiroth Tubes / Valves 12 7th June 2002 01:27 PM
Copyright ©1999-2017 diyAudio
