| diyAudio Sponsor | ||
I just inherited a "vintage" Gibson Skylark GA5T Amp. It sounds pretty good but there is a definite hum and ... (this is the bad thing) when it is swithed off the metal and my guitar go hot! its a low voltage but definitly a tingle! Attached is a link to the schematics. I want to ground the chassis and I am checking for shorts. I probably need to install new isolated input jacks. What else do I need to watch for or is there a good reference. This is my first "project' amp. I am new at this so keep it simple, please. Thanks.http://www.harpamps.com/gibson/pg_0089.jpg
#2 |
It's easy that the 0.02uF capacitor in the primary of the power transformer is leaky or shorted. Remove it, it's not needed, and replace the power cord with an earthed one, 3-prong.
While you're here change all other capacitors. |
#3 |
Although no leakage issues of line voltage, a new 3-prong cord replacing the stock two prong power cord removed all audio hum on our Gibson Hawk.
| Gibson EH 150 restoration | mattnorthrop | Tubes / Valves | 15 | 26th March 2009 08:09 AM |
| 60's Gibson 210 | Redfoxfur | Instruments and Amps | 13 | 8th May 2008 02:50 AM |
| gibson amp lp JR | jjac7212 | Tubes / Valves | 1 | 7th April 2008 12:55 PM |
| Need help cloning a Gibson g-20 amp | DeadSpeaker | Solid State | 41 | 8th March 2008 08:37 PM |
| What is Gibson thinking? | cyclotronguy | Instruments and Amps | 19 | 7th September 2005 07:57 AM |
| Page generated in 0.06543 seconds (71.36% PHP - 28.64% MySQL) with 11 queries |
