| diyAudio Sponsor | ||
Hi there
I built a clone of the Conrad Johnson PV10A, and was wondering if it would be possible to mod it for use with 6922 tubes. Regards Dirk |
#2 |
Yes you can, but that is like a new preamp. you have to change the cathode resistors for proper working, the RIAA must change and so on. The B+ supply is a little bit high for 6922.
Reinhard |
#3 |
B.T.W. plaese ignore the phono stage. I am only interested in the line stage. Here is the component list.
#4 |
You can use the same topology, but going from a 12A*7 type to 6922 will involve a complete redesign. All operating points will be different, gain structure will be different, power supply requirements will be different, biasing will be different. Other than that...
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#5 |
If I see the tubes right, they are 12AU7 to be replaced with 6922. Have you tried Brimar 12AU7 or Amperex 6085? They may outperform the 6922.
Note: 600 ma on the 6085 filaments, should not be a problem with the transformer operating too hot. |
| 6922 Tubes | techno | Tubes / Valves | 9 | 8th April 2012 10:33 PM |
| WTB: E88CC 6922 Tubes | jjaudio | Swap Meet | 4 | 20th May 2011 12:29 PM |
| Quality 6922 Tubes | AKSA | Tubes / Valves | 8 | 12th May 2003 01:13 PM |
| WTB: 6922 tubes | bbaker6212 | Swap Meet | 14 | 28th November 2002 05:31 PM |
| Page generated in 0.08188 seconds (72.78% PHP - 27.22% MySQL) with 11 queries |
