| diyAudio Sponsor | ||
#2 |
Meh, I'd just use a 220uF SMPS cap rated for 450V. Rob one from an old computer PSU - they're almost always good, even if everything else is smoked
** edit ** You might wanna use uF instead of mF there - 200mF is 200,000uF and will cost you plenty
#3 |
Hi dstockwell,
Your 200 uF cap is a pair of 100 uF's in parallel. It's rated at 500 VDC like the other dual 100 uF. You need the 500 V rating for the period in time before the outputs draw current and drop the supply voltage. You may be able to get away with 450 VDC. With no tubes in circuit, install a smaller 500V cap and read the voltage. Also note the AC supply voltage and leave some safety headroom. -Chris |
#4 |
Hi dstockwell,
Also, after you have it running, note the level of hum in the output. Then try to bias the heater strings up to 30~40 VDC via a bleeder string from B+ to common, add a cap to common from the bias point. Sometimes larger caps will generate a buzz due to the higher peak currents due to the higher capacitance. -Chris |
#5 |
OK I am way confused then, is the 100/100 uf @ 500 the same as the can capacitor on Wellbourne 100uf x 100uf/500V
I figured 2 of these according to the schematic if not I am lost guess I got way more to learn before I try doing even the easiest of schematics.
#6 |
Hi dstockwell,
Yes, you have it right. The schematic should have indicated a pair of 100 uF capacitors, not a single 200 uF. -Chris |
#7 |
So I eliminate the 200 shown and place the (2) 100/100 in the (2)100mf spots.
#8 |
#9 |
You install a 100 / 100 @ 500 in the 200 uF spot. You then install one section of 100 / 100 @ 500 in the two 100 uF spots. Or you can use four capacitors depending on layout and space.
That should do it. Again, you may be able to use 450V units instead of the 500V specified. Test and measure first. -Chris |
#10 |
Thank you very much I understand now.
| Best PS capacitor | RFENG | Parts | 3 | 19th January 2008 02:44 PM |
| what capacitor is this? | abiedoodles | Parts | 10 | 12th December 2007 07:11 PM |
| Capacitor Help | MorePower7701 | Solid State | 8 | 25th July 2007 06:41 PM |
| Capacitor esl | dhole | Pass Labs | 1 | 23rd April 2005 02:18 PM |
| Capacitor or not? | future | Parts | 2 | 24th June 2003 11:10 PM |
| Page generated in 0.10578 seconds (76.36% PHP - 23.64% MySQL) with 10 queries |
