| diyAudio Sponsor | ||
Does anyone have good links for learning how to design a PSU for a tube amp? I am interested in both tube as well as solid state rectification. My particular needs are for something that will provide a B+ of about 120V and that can supply a current of 60mA, but I am interested in general links.
http://www.ecpaudio.com |
#2 |
http://www.duncanamps.com/psud2/index.html
Download the software and you would have fun with it. Johnny |
#3 |
I've seen the software. I am more looking for some background reading to help me get started? Any thoughts?
#4 |
emission over emittor |
#5 |
diyAudio Moderator Emeritus
Have you read this one the so called neets course?
I have chapter 6 on my site http://www.basenjes.de/tubes/data/neets_ch6.pdf |
#6 |
The power supply master "cheat sheet" from Hammond.
What sort of rectifier/filter will give what voltage and current etc. http://www.hammondmfg.com/pdf/5c007.pdf Cheers. Ian |
#7 |
Both web sites are of a more general nature, but they have areas within them which address tube PSU design and I've found them useful: check via Google both "Steve Bench", and "electronics 27". I tried to post the links for you but could not get them to work properly.
#8 |
| learning hornresp with staiper design | jaya000 | Multi-Way | 4 | 26th February 2009 05:46 PM |
| power tubes and learning SET design | cbutterworth | Tubes / Valves | 34 | 16th December 2007 01:25 PM |
| learning design but need help | lochness | Tubes / Valves | 11 | 18th October 2007 02:23 AM |
| Help for learning subwoofer design | neutral | Subwoofers | 5 | 3rd September 2005 11:28 AM |
| Page generated in 0.09515 seconds (79.22% PHP - 20.78% MySQL) with 10 queries |
