Fluorescent lamp choke - use in tube amp?
Old 17th September 2005, 10:13 AM   #1
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Lightbulb Flourescent lamp choke - use in tube amp?
Hello to all!!!
I found a flourescent lamp choke (you know, heavy white things mounted near the lamp starter). It has 45ohm dc resistance which I just measured. And it has these writings on it:
Type:N/39 Lamp W:30-32-2x14-15 [delta]t:55 tw:120
V:220 Hz:50 And then some semi-cancelled letters:
IL (or maybe TL): 0.xx 0.xx (those x are unreadable numbers)
cosx:0.45 (the x maybe a greek phi)
(note: the [delta] is in greek letter)
What does they mean? How a flourescent lamp works? What does the starter do?
And most important... if this is a choke, can I use it in my tube amp just to filter the B+ for the screens of the power tubes (2 EL84 per channel) and for the anode of the drivers (a couple of ECCxx series)?
Thanks in advance!!!
Old 17th September 2005, 10:28 AM   #2
kmtang is offline kmtang  Canada
kmtang's Avatar
I believe the choke used in florescent tube is for AC operation. The one we are using for B+ filtering is for DC.
With DC current through a choke designed for AC operation, the magnetic core mostly get saturated and its Inductance will become less significantly.
Just my 2 cents.
Johnny
Old 17th September 2005, 11:02 AM   #3
silicon-surfer is offline silicon-surfer  Australia
Default How a fluorescent lamp works
A fluorescent lamp works by passing an arc from one end of the lamp to the other. In each end of the lamp there is a small filament like the filament in an incandescent lamp, which is ignited briefly to heat the gas inside the lamp - this is done by the starter which switches the filaments on for a moment and then off (usually several times which is why fluorescents flicker when they come on). The gas inside the tube is a mercury vapour which produces ultra violet light when the arc passes through it, and then the phosphour coating on the inside of the glass of the tube converts the UV to visible light.
The Choke in a fluorescent lamp limits the current that flows through the lamp after the lamp has ignited.
Don't know how this helps with a tube amp though!
Old 17th September 2005, 11:06 AM   #4
Giaime's Avatar
Default Re: How a fluorescent lamp works
Thanks!!! I've searched the net and now I understand how a fluorescent lamp works. Now I'd like to know if someone is using the reactor choke in a tube amp...
Old 17th September 2005, 11:06 AM   #5
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
discussed long time ago on r.a.t
it works
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 17th September 2005, 11:07 AM   #6
Giaime's Avatar
it works
r.a.t.????? Sorry I don't know this.
Old 17th September 2005, 06:42 PM   #7
amperex is offline amperex  United States
The small & common 13-watt twin tube reactors have little inductance. The small inexpensive $8 to $10 Hammond chokes are superior for filtering in power supplies.
Old 19th September 2005, 01:10 PM   #8
gainmona is offline gainmona  Italy
In the last number of italian magazine "Costruire HiFi" (Building Hi-Fi) is a project of tube pre-amp using a fluorescent lamp choke in the PSU who seems work wery well.
Ciao.
Old 19th September 2005, 01:13 PM   #9
Giaime's Avatar
Ciao.
Thanks!!! Anyone has details on this misusing of that choke??? I understand that Hammonds are better, but here in Italy 20 euro + 10s/h.... a bit high.
Old 19th September 2005, 02:44 PM   #10
Ouroboros is offline Ouroboros  England
Ouroboros's Avatar
Probably the usenet news group: rec.audio.tubes
Fluorescent lamp choke - use in tube amp?Hide this!Advertise here!
Tube amp transformers 4 pwr 4 output 1 choke (used) Westerp Swap Meet 0 18th May 2009 07:37 PM
Choke loaded PSU versus VR tube regulated PSU? G Tubes / Valves 37 20th March 2008 10:45 PM
"40w fluorescent lamp inverter" Gunawan W Everything Else 1 3rd March 2007 09:24 AM
Tube as a desk lamp AudioGeek Tubes / Valves 14 1st February 2006 11:23 PM
Dual-Coil Choke for Tube Preamp CLS Power Supplies 13 18th July 2005 02:22 PM
Copyright ©1999-2017 diyAudio
