| diyAudio Sponsor | ||
I found a 300B schematic from Bob Danielak and tried the e-amil with no response. I have some issue's with some 1K vs 100K vs 100 (no K marked), would you experts please review my redraw and help, please.
These are the orginals |
#2 |
PS
#3 |
Redraw
#4 |
I just designed this direct-coupled 1626 driver for an amp I am building. Very similar to this design, but driver is direct coupled and choke loaded (use cheap 60H/30mA Handmade Electronics choke).
This should be a big bad driver stage - it could be a 1W amp all by itself. In fact, I plan to build it as a DC-Darling amp at some point. I am using a 6sn7/6j5 as the input tube. If you do this DC thing, use a 12vct filament transformer for each 1626 and connect the canter tap to the cathode to minimize filament-cathode potential, often a problem with DC designs. jsn |
#5 |
2 things:
1) The values on the schematic you posted look correct. I didn't see any obvious errors. 2) I forgot to draw a grid resistor in the scematic I just posted. please use whatever your preamp wants (or a pot or whatever). 100k seems to be "standard". I am working on a followup to my little "hi fi primer" that will show folks how to work through a direct-coupled design and will probably use this 6j5/6sn7-1626 amp as the example. I promise to build it and everythig to prove it works. Check here for updates: http://boozhoundlabs.com/ jsn |
#6 |
4.8K impedance OPT seems too large for the 300B. I prefer running it with 2.5K to 3.5K.
#7 | |
If I use a lower K OPT @ which MA value do I use. The one in the schematic is 110MA. |
#8 |
The current through the out put transformer will be the same. The impedance listed is not DC Resistance, but the ac impedace presented to the 300b, determined by the ratio of primary and secondary windings and the load placed across the secondary - the speaker.
A higher impedance ususally results in lower distortion, and slightly less power. jsn |
#9 |
Bob Danielak's values seem all fine. In the 'redraw' the gridstoppers are 100k which is obviously silly - they should be 100R on the 300B and anything between 100R-1k on the other tubes depending on taste.
#10 |
thanks analog, it will fix the redraw.
| ADC Board - Any chance of some schematic review? | dmills | Parts | 0 | 21st September 2008 03:26 PM |
| PCM2707 Schematic Review | bacworth | Digital Source | 10 | 6th May 2007 06:18 AM |
| for review | markmelheim | Multi-Way | 2 | 16th May 2005 01:42 AM |
| And another review (X2.5) | Duck-Twacy | Pass Labs | 0 | 23rd November 2003 05:42 PM |
| Page generated in 0.10098 seconds (75.35% PHP - 24.65% MySQL) with 11 queries |
