| diyAudio Sponsor | ||
Hello!
I recently got my first taste of tube amp goodness... Now i'd like to build something small , around 8+ watts per channel. I don't want to have a very complicated power supply as i'm a bit of a wuss when it comes to playing with mains Does what i'm asking for exist? Thanks! |
#2 |
Audionote Kit 1 .
#3 |
Poindexter's "Machine" is a NICE 8 WPC piece and a line stage is not needed. However, the "Machine" has a B+, a B-, and a C- rail. That sort of PSU is an important part of a truly elegant unit.
I'm scoping out an 8 WPC amp at a less elegant level than Poinz's "Machine", but I SHAMELESSLY borrow some of his ideas. "El Cheapo" does not have a C- supply, as it uses cathode bias instead of adjustable fixed bias. The B+ and B- rails are present. If the voltage of tube B+ supplies gives you pause for thought, maybe you should build a hybrid amp with "sand" finals and 6GM8 based voltage amplification. The 6GM8 is a low voltage relative of the 6DJ8 that works at rail voltages seen in SS gear. AMOF, 28 V. or so is as high as you can go on a 6GM8 plate. Poindexter's Site "El Cheapo" Project
Eli D. |
| Simple Super Shunt and Simple Super Shunt w/CCS vs. JSR03/05 (and other series regs) | hollowman | Power Supplies | 44 | 7th October 2009 07:01 AM |
| The Super-Simple ChipAmp, Pt. II | Spasticteapot | Chip Amps | 4 | 5th November 2006 11:43 PM |
| Help a total tube amp newbie find a super simple design... | nerd of nerds | Tubes / Valves | 24 | 27th March 2006 12:28 PM |
| Super Simple battery charger... | dcole | Digital Source | 4 | 7th February 2004 01:52 AM |
| Page generated in 0.06471 seconds (70.39% PHP - 29.61% MySQL) with 10 queries |
