Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Tubes / Valves All about our sweet vacuum tubes :)
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 13th September 2005, 07:59 PM   #1
aletheian's Avatar
Default Could you guys check this cascode article for me
Would one of you please proofread this article for me. I wanted to put together an explaination of cascode circuit design in plain terms for DIY guitar amp builders, and I want to make sure it is not off base anywhere. I'll add you guys in the credits as editors if you want.
http://www.geocities.com/keirkegeerd...ddingdiyer.pdf
Thanx a million for all your help!!!!!!
Old 13th September 2005, 09:06 PM   #2
EC8010 is offline EC8010
EC8010's Avatar
It's the input resistance of the following stage in combination with the coupling capacitor that sets the low-frequency roll-off. That's why self-bias cathode followers can get away with such tiny input coupling capacitors.
Can I suggest that you let a spell-checker loose on your text, also that you practice using the shift key on things like "ECC88" but use lower case "k" for "kilo" because "K" is short for "Kelvin" (the unit of absolute temperature).
"Scientific progress goes boink." Bill Watterson
Old 13th September 2005, 10:17 PM   #3
cerrem is offline cerrem
The article seems not regimented...There does not seem to be a structured design process....It seems to be a lets try this and lets try that and see where the numbers lead us....
I guess that works for musicians but that would not fly in the engineering environment....
Rp, gm...ect.. Are determined based on the operating point choosen...not from the numbers given in the data sheet, unless you operate at the same conditions as stated in the data sheet.
As for the origins of the ciruit.... You can call it a TRANSIMPEDENCE amplifer..... The top triode is acting as a voltage regulator...actually a cathode follower voltage regulator...
It is passing along the AC signal current to the load at the very top...in that sense it is gm.... To qualify as a gm amp you would have to come up with bigger numbers for the effective output resistance....
Chris
Old 13th September 2005, 10:27 PM   #4
SY is offline SY
SY's Avatar
Minor stuff: separate, not seperate. "Its" for possessive, not "it's."
Don't feel bad, EC8010 tweaked me about my use of "K" where I should have used "k" in my Heretical post.
"It is not seemly, after wiping your nose, to spread out your handkerchief and peer into it as if pearls and rubies might have fallen out of your head." - Erasmus
Old 13th September 2005, 11:43 PM   #5
aletheian's Avatar
HA. Yeah, I didn't spell check it yet, I wanted to make sure that the math was cool first. Thanx for all the replies. I would not presume to be able to write anything on en engineering level, but I want to help guitar amp guys understand this stuff a bit better...hence the slang and fun language. I also chose operating points that would get me some results close to a typical gain stage in a guitar preamp to, so that's why the numbers are a bit wacky.
-("...It's the input resistance of the following stage in combination with the coupling capacitor that sets the low-frequency roll-off. That's why self-bias cathode followers can get away with such tiny input coupling capacitors...")
I have that math in there. In the other section I was referring to the effects of a the Ck capacitor in regard to a partially bypassed cathode resistor as a treble peaking circuit.. guitar amp guys call that the frequency response of a stge, but I don't know if that is right. You are right about the lower case K too, I was just being lazy with the shift key.
-("Rp, gm...ect.. Are determined based on the operating point choosen...not from the numbers given in the data sheet, unless you operate at the same conditions as stated in the data sheet.")
...yeah...I know. i had a heck of a time finding a set of curves for any modern tube that show transconductance at a given operating point. I found one for a 6dj8 and used that to estimate. I found a runup that Steve Bench did on a 6H30 too, which was cool. I found a few 'rule of thumb' formulas for Gm, but nothing solid... lots of mystery out there. BUT, are you saying that a textbook cascode is not a gm amp? That I do not understand.
Thanx again!!
Old 13th September 2005, 11:45 PM   #6
SY is offline SY
SY's Avatar
It's a transconductance amp in the same way that a triode is- i.e., if you attach it to a load resistor, it acts as a voltage amp. But as a package (load resistor included), it's a voltage amp.
Old 14th September 2005, 12:05 AM   #7
aletheian's Avatar
Gotcha. I'll omit those references. Do I have all the formulas right (and applied properly)? That is my main concern. Most guitar preamps run between 300v-400v in the preamp section, so that figure is pretty much chosen for me though.
Old 14th September 2005, 03:15 AM   #8
Sorry..
I re-read the article and now see the proper equation I did not see before.... It was the Zo equation.... which is correct... So yes I do now agree with you about seeing it as a gm amp based on the equations in your article...
Personally, I got lost in all the clutter...I prefer just a paragraph explaining functionality of the circuit and another few paragraphs showing derivation of equations....then a final cleaned up version of the essential equations.....
I did get confused with the RED line that is drawn in plate curves graph???? The lower cascode "idealy" sees no load on top and should be "locked in" at a set plate voltage ..so there should be no signal movement at the plate of the lower valve...therefore the movement should be strictly VERTICAL on the graph, behaving in accordance to gm....you can see the spacing is horrible when moving VERTICALLY with this triode, worse than a pentode...this radical delta in gm will fuel harmonics ...which is great for guitar.... As we all know , in real life there is a finite impedence looking into the top triode from the bottom triode's perspective... thats why I use an active negative feedback from that node to the upper triode grid.... This effectively lowers the looking in impedance of the upper triode..and now you approach ideal Gain.... A lot of trouble for little more improvement....
Chris
Old 14th September 2005, 04:24 AM   #9
aletheian's Avatar
Yeah, I did ask elsewhere on this forum about plotting a line for the bottom tube when I realized that it should start around 300mA for the circuit I used... almost a frigging straight line. CRAP!!! You are right...I forgot to change that paragraph, good call.
By active feedback, are you referring to a self bias configuration, where the top tube's grid is tied to the bottom tube's anode?
Maybe I'll redo the article so that it is more step by step. If the experts can't follow my jumbled mess, then how can I axpext a noob to?
Tell me, is this chart a better representation of the operating point:
Old 14th September 2005, 04:29 AM   #10
aletheian's Avatar
Default One more thing
I know the formula gm=dIp/dVg, BUT is there any way to figure out what the gm of a tube will be at a particular bias point without plotting it on a dynamic curves sheet? OR BETTER YET. Does anyone have a graph of a 6922/6dj8/e88cc/6h30 that shows the curves for gm against current?
Thread Tools
Found a good article on using a microscope to check stylus wear ALustyGhost Analogue Source 0 17th November 2008 02:53 PM
Fact Check on My Enclosure Article BAM Subwoofers 2 29th October 2004 11:38 PM
Page generated in 0.23277593 seconds (82.71% PHP - 17.29% MySQL) with 11 queries
Copyright ©1999-2009 diyAudio
