diyAudio Sponsor
Old 14th September 2005, 04:36 AM   #11
aletheian's Avatar
Default grrr...
I'm really pissed now that I forgot to change that paragraph... now I have to do the math for the whole thing over again.
Old 14th September 2005, 06:18 AM   #12
cerrem is offline cerrem  United States
As long as the cathode resistor is bypassed..then the RED line is the slope representing 1/gm of the top valve.....
I have the gm curves for a 6922 ...but not with me... There is a book that has them...maybe someone here can help with that..
As for active feedback.....I am refering to using an inverting op-am in the feeback loop between the lower anode and the upper tubes grid...while still maintaining the DC reference voltage...
Chris
Old 14th September 2005, 06:11 PM   #13
aletheian's Avatar
Chris
INVERTING OPAMP! Brilliant. I would never have thought of that.
1/gm for the slope eh? I guess for a rule of thumb, I could use a straight line since 1/12,500 is off the chart anyway.
I think what I need to do is invest in a book of complete tube curves. Last night I actually found a 36 page PDF from Phillips that has all the curves I need, INCLUDING a graph for a 6922 in cascode... boy would that have made life easier
Found a good article on using a microscope to check stylus wear ALustyGhost Analogue Source 0 17th November 2008 02:53 PM
Fact Check on My Enclosure Article BAM Subwoofers 2 29th October 2004 11:38 PM
Page generated in 0.07673 seconds (66.88% PHP - 33.12% MySQL) with 11 queries
