Stereo build- Mikael Abdellah's KT88 SE amp
Old 8th March 2018, 02:30 AM   #121
arold19 is offline arold19
I use this amplifier since a couple of year now with a low fillament voltage of 5.7V since the 6.3V specification... Do you think it is a good idea to correct that problem? First of all, my power transformer have 3 output of 6.3, I use one output for each tube! I have 119.5V from the wall... The DC output is 400V dc... When I try the 110V input (tap) of the transformer, I have 6.4V to the filament and 440V supply so. Can I run this amplifier at this high voltage without any problem? 6.4 is a little bit high? I can put resistor to drop that voltage? Can I add a resistor to drop to 400v?
Thank you!
It is a good idea to put 2 X 100 ohm resistor directly at the output of the power transformer?
[IMG]C:\Users\Gabriel\Desktop\Gabriel\power supply.png[/IMG]
Old 8th March 2018, 02:44 AM   #122
Old 8th March 2018, 12:28 PM   #123
tim614 is offline tim614  United States
tim614's Avatar
Have you try a different rectifier like a 5r4
Tim
" perfect imperfection "
Old 8th March 2018, 01:42 PM   #124
The 5u4 tube have about 44v drop and the 5R4 is 67V.... so I will loose about 23V. I think this will be perfect. Excellent Idea, I will order a new rectifier tube!
Thank you Tim614.
Old 10th March 2018, 12:34 AM   #125
There a lot of 5R4 tube and I'm a bit confuse... 5R4GA, 5R4GB, 5R4GY ???
I reed that the max value for the input cap is 4uF for this rectifier?
Which one I can try?
Welcome to TubeDepot.com!
Stereo build- Mikael Abdellah's KT88 SE ampHide this!Advertise here!
Improvements for the Mikael Abdellah KT88??? 69CamaroSS396 Tubes / Valves 43 4th August 2017 07:49 PM
Mikael Abdellah's KT88, Loadlines soundbadger Tubes / Valves 7 4th June 2017 02:08 AM
6CA7 Mikael Abdellah's KT88 SE amp? porkchop61 Tubes / Valves 24 20th February 2011 03:31 PM
Mikael Abdellah SE KT88 ideas and questions kacernator Tubes / Valves 6 14th January 2008 01:09 PM
Looking for KT88 Amplifier Schematic by Mikael Abdellah jduffy Tubes / Valves 6 5th April 2007 09:02 PM
