diyAudio Sponsor
Old 12th September 2005, 05:05 PM   #1
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Default Simple EL84 PP design needed
Hello there!!!
I've got the iron to build an EL84 stereo PP tube amp. I've got an old stereo tube amp that I'm cannibalizing for this project. It has a power tranny (don't know voltage or current ratings), a GZ34 recto, an ECC82 as driver and 2 EL84 for each channel, and good output transformers (judging from the size and the construction, but don't know the impedance). Also it had a complete pre (including phono stage) with another 2 ECC83. Since I want only a power amp, I'll eliminate these. The filter caps were rated at 350V, so I will expect to see 300-320V after the rectification.
What I want is an extremely simple design (no ccs and similar), cathode biased, pentode/triode switch, little NFB, driven by either ECC82 or ECC83, either two (each channel gets one) but it would be better to have only one to drive both channel. I would like to keep it tube rectified.
It will take the output from an SS integrated amp preamp section (for now it's a NAD3020), but I plan to add a tube pre later. So input sensitivity should be around 2Vrms for full output.
Can anyone help me? I've searched the forum but I can't find anything really simple...
Old 12th September 2005, 05:21 PM   #2
cerrem is offline cerrem  United States
Take a look at the Fisher SA-16 and the SA-100 schematics.....
These are as simple as it gets for EL84 amps...but descent quality...
The power supplies on the SA-100 used massive voltage dropping resistors.....Obviously you can eliminate and simplify the power supply for your application....
Chris
Old 12th September 2005, 05:28 PM   #3
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Default I am sorry
but you have to enhance your searching abilities.
There is another active thread that gives everything you asked for:
Searching for simple circuit
It is about the so called poindexter amp. 6v6 can be exchanged by el84
Old 12th September 2005, 06:31 PM   #4
Giaime's Avatar
Default Re: I am sorry
I don't think so. They are different tubes (6V6 is not a pentode btw), my request was very precise. I asked "with this stuff what schematics should I follow"? not "which amp should I build".
I'm thinking of designing it by miself, it shouldn't be hard.
Old 12th September 2005, 06:40 PM   #5
SY's Avatar
Why ECC82/83 in particular? ECC83 can work OK as an input tube, but is pretty weedy as a driver. ECC82 has rather high distortion. Other tube choices are cheap, why not consider them?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 12th September 2005, 07:07 PM   #6
Gabevee's Avatar
Here is a simple schematic for the EL84, and you can sub the 6EU7 with your ECC83. In this circuit they will do the job nicely. Very simple, few parts, and surprisingly effective.
http://members.tripod.com/~gabevee/maggie.html
Skip all the text and go to the center of the page. You will see one half of the two channels. Just make sure you tie all four output tubes's cathodes to the one 100 ohm paralleled with the 22 uF cap.
You can make the power supply any way you desire, or follow this one:
http://members.tripod.com/~gabevee/mypwrsup.html
The first and second schematics use indirectly heated and directly heated cathodes respectively. With the components used, it is a most effective power supply.
Hope this helps!
Gabe
Gabe CGV Electronics
Home of the CGV-300B amplifier on a budget
Old 12th September 2005, 07:23 PM   #7
jackinnj's Avatar
if you Google "EL84 Push Pull" you will come up with a ton of designs. Here's one I liked: Claudio's site
http://www.bonavolta.ch/hobby/fr/audio/el84.htm
Old 12th September 2005, 08:20 PM   #8
Giaime's Avatar
Thanks!!! I will go throught them and see what's the best for me... thank you all!
Old 12th September 2005, 08:37 PM   #9
richwalters's Avatar
try typing -> russ valveamps on Google theres lots of schematics for all sorts.
richj
Old 12th September 2005, 08:59 PM   #10
Giaime's Avatar
Thanks, but can someone point me to a design that uses a SINGLE triode section (of whatever tube) to drive a couple of EL84??? All those designs show many stages, some of them also (aaargh) tone controls, instead I want to keep the thing extremely simple. I need a driver stage with only 1 triode section that does the phase splitting and also the gain to drive properly a couple of EL84s.
Thanks so far!!!
Simple EL84 amp... Skorpio Tubes / Valves 11 3rd January 2009 08:25 PM
Simple EL84 Mas Penk Tubes / Valves 25 17th August 2006 01:55 AM
Help needed for LM3875 design + simple single-sided PCB. Spasticteapot Chip Amps 12 2nd April 2006 07:25 PM
newb needs help on simple el84 amp PS DJNUBZ Tubes / Valves 28 16th December 2005 05:47 PM
Simple 6L6 PP Guitar Design Needed Trout Tubes / Valves 1 7th September 2005 03:20 AM
Page generated in 0.10766 seconds (84.22% PHP - 15.78% MySQL) with 11 queries
