| diyAudio Sponsor | ||
About two years ago I built Frank’s pre-amp (12BH7A in a WCF configuration).
Frank's Ultimate Tube Preamp. After that he published a schematic with a little gain, using a SRPP 12BH7A into a 12BH7A WCF. I was tempted to build it…but than the Aikido already made his entry in the scene and I didn’t exactly know what to build anymore. I remember Frank posting a comment that the Aikido was new for him, but short after that he posted the schematic of the SRPP 12BH7A + WCF 12BH7A again, to show it had lots of things in common (at least in the wiring). So I thought about the possibility to build something more universal, which implies in the possibility to easily change cathode/plate resistors for different tubes/current settings. I didn’t want to solder and desolder it every time and I finally found a solution for this, inspired through http://www.artemislabs.com/docs/PL1_Manual_1.pdf amplifier - the ZIF socket. With this one it’s possible to easily change resistors, and it probably will work very well. For other connections it is possible to use jumpers (well, I will build a prototype on veroboard, so it is easy to use jumpers). Today I spent some time in designing the more universal preamplifier. Well, it is not actually designing, I just put some freely available schematics together. With different settings of the jumpers it should be possible to 'create' a SRPP amp, a WCF, a SRPP + WCF, an Aikido and a Gomes amplifier. Issues like the power supply and exact values for the cathode resistors (and the plate resistor in the SRPP) I haven't put here. Power supply van vary a lot. A 6BL7 in SRPP will be happy with 390VDC, almost the double of what the ECC88 can take...so power supply depends on used tube (B+ aren't tied together, but should be). The Aikido design allows one to change tubes without changing cathode resistors, but I like the idea to easily change the settings of the used tubes - that's why I will use the ZIF socket (in the schematic a 'ZIF connection' is shown as two parallel lines, a bit like a capacitor). Jumper pins are shown with the dots, the actual jumpers with red lines. I post it here and I am sure comments will arise, given the popularity of the Aikido and the 12BH7A WCF, about two years ago. First schematic is that of the SRPP 12BH7A + WCF 12BH7A Erik PS: and if it all seems to strange - I got the 'valve amplifiers' book as a gift for my graduation and I can take some theory from there. |
#2 |
the 'universal' amplifier - all those dots.
#3 |
Jumpers set for SRPP operation. Note that the second tube is not needed here.
#4 |
Jumpers set for WCF. Now the first tube is not being used.
#5 |
SRPP + WCF (gain + output buffer)
#6 |
The Aikido - safe version
#7 |
And why not - jumper settings for the Gomes
#8 |
diyAudio Moderator Emeritus
Wow..great Erik...I would call it universal gain stage though..because you could just as easily use it to drive an output tube...etc..etc.
#9 |
WOW.
#10 | |
Attached is a version with three more ZIF 'slots', allowing the assembling of the 'simple line stage' from John Broskie. Only the first tube is used (it should be a 12BH7A). And so you can go on... Erik |
| Infinity: an universal guitar preamp | danV | Instruments and Amps | 2 | 24th December 2011 07:20 PM |
| I want to build a preamp for my dad.. thoughts? | 240z4u | Tubes / Valves | 32 | 22nd April 2009 01:32 AM |
| Any thoughts on this Philly Audio preamp design. | Wtlng | Tubes / Valves | 8 | 14th January 2006 12:59 AM |
| Best BOSOZ preamp parts selection thoughts | hifimaker | Pass Labs | 94 | 23rd March 2005 06:47 PM |
| Page generated in 0.10989 seconds (79.87% PHP - 20.13% MySQL) with 11 queries |
