| diyAudio Sponsor | ||
Will the Aikido circuit need the cathode resistors altered if you were to use 12AX7's and HT of 260V, If so is 1K1 The correct value for 1.1mA? Cheers Craig |
#2 |
Quick answer:
"Will the Aikido circuit need the cathode resistors altered if you were to use 12AX7's and HT of 260V, " Yes (preferably). "If so is 1K1 The correct value for 1.1mA?" No. You would seem to require about 800 ohms. 820R is the closest E12 standard value, which will be fine. Morgan |
#3 |
Excellent, thanks a lot Morgan.
Craig |
| Aikido question | kacernator | Tubes / Valves | 6 | 22nd April 2008 11:40 AM |
| Quick quick question ! | guitvinny | Pass Labs | 6 | 7th February 2007 04:20 PM |
| Aikido question | SteveA | Tubes / Valves | 10 | 20th November 2006 08:30 PM |
| VERY quick question... | Wyloch | Multi-Way | 2 | 3rd March 2005 04:34 PM |
| Quick X-over question | DerekB1 | Multi-Way | 1 | 17th January 2005 07:29 PM |
| Page generated in 0.06843 seconds (70.16% PHP - 29.84% MySQL) with 11 queries |
