Anyone tried the Hammond 1642SE in a BIG SE amp?
Old 4th February 2010, 10:16 AM   #11
JamesHill is offline JamesHill  United Kingdom
Hi Tony,
I was actually inspired by your postings in other threads about your 826 amplifier to build one.
Unfortunately I had a very hard time getting good 826 Valves. Of the 7 I tried I found only 1 good one.
So I have now moved on to a 833 SE, (as well as a GM70 PP!)
The Hammond's are on order so will post back when I make some progress.
Best Regards
James
Old 4th February 2010, 02:38 PM   #12
Tubelab_com is online now Tubelab_com  United States
Tubelab_com's Avatar
I did a amp 1642SE with 826 in Shisido style, 1.25k load for 826 was what he designed, but out-put only 8 watt, SE amp most for sound quality not for power, I use my 826 for supper high section in multi amp system
Did you ever measure the frequency response? I posted this question about the 1642SE over 4 years ago because of my bad experiences with the 1628SE.
I got a pair of 1628SE's. Their frequency response was 6db dowm at 20KHz with a sharp notch at 28KHz. The phase shift across the high frequency end of the audio spectrum is not normal either.
I have since tried the 1628SEA and found it to be better, but still not meeting the published specs.
"Frequency response at least 20 Hz. to 20 Khz. at full rated power (+/- 1 db max., ref. 1 Khz.) "
I could consider a project using the 1642SE in the future, but not until someone has independent test data on one.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 4th February 2010, 03:23 PM   #13
makaiyumtony is offline makaiyumtony  Canada
Old 4th February 2010, 05:14 PM   #14
sorry something wrong of my computer I reply again, I built that amp around 8 years ago and I don't care too much of distortion and frequency although I got things to check. mainly for the out put power, the rest by listening judge only. looking for transformer go for over 20K but the speakerwill not follow, in multi system gain control in crossover will adjust to match the others for best result
Old 9th April 2012, 09:50 PM   #15
dztronic is offline dztronic  Viet Nam
I just "bite a bullet" and purchased the 1642SE. Life is not rose at all. It has a dip/resonance right at 17.4 kHz with the 8-Ohm output. The 4 and 16-ohm outputs does not have this dip but none of them better than 28kHz ... Moreover, somehow the winding ratio is totally off from spec. I will check the winding ratio again but the dip/resonance is definitely there. I am contacting Hammond Canada engineer and waiting for their feedback. Hammond in US and resale in US cannot help any technical issue.
Old 11th September 2014, 11:54 PM   #16
cyclecamper is offline cyclecamper  United States
I realize this thread is 2.5 years old...but that passes in the blink of an eye for us old farts.
So, was the winding ratio issue making the transformer's source impedance higher or lower than the 5000 rating? Got any data with the 16-ohm output tap, where the winding ratio is less?
Old 11th September 2014, 11:56 PM   #17
Advertised prices are all over the map, with Digi-key at $320.81 which is $100 less than some others.
Old 12th September 2014, 02:33 AM   #18
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
Why use a SE OT at all? The "anti-triode" scheme solved this years ago.
You put the tube on one side of a P-P OT, and a high gm HV Mosfet on the other side of the OT primary. Then a CCS tail below them both. The tube gets driven by the audio, and the Mosfet gets a quasi static DC bias. The tube will generate some inadvertant DC imbalance with large signals due to its 2nd harmonic distortion, so some provision is needed to dynamically adjust (below 10 Hz audio band) the Mosfet gate bias to keep the DC in the OT in balance.
This gives twice the power output as the single tube alone would give, and the CCS tail along with the high gm Mosfet guarantee true complementary current in the opposite OT primary phase. The high gm of the Mosfet keeps the voltage on the tail constant, so the tube operates in a SE environment. (normal P-P split phase operation cancels the even harmonic distortion by dynamic (audio band) variation of the tail voltage, which is not allowed here.)
Remember the EL Faro.
NTSB: The captain "was overly confident, would not listen to the advice of his officers".
Old 22nd February 2015, 11:39 PM   #19
mlise is offline mlise  United States
[IMG]Click the image to open in full size.[/IMG]
I think the only high voltage high gm FET that will stand off 3KV+ is another 3-500ZG. Doubling the b+ current is also pretty impractical for an amp that will burn a kilowatt at idle. The balancing current could be from a low voltage buck regulator on another winding, or maybe the filament current.
I bought a pair of 3-500Z's 20 years ago. Maybe I'm old enough now to not kill myself hooking them up. If there are performance issues with the 1642SE, Is anyone interested in a group buy of a custom at Stangenes? Places I've worked for have gotten great service and customs from them.
Old 23rd February 2015, 04:45 AM   #20
wrenchone is online now wrenchone  United States
wrenchone's Avatar
Actually, IXYS has some 3 kV+ devices. They're even available at Digi-key, but be prepared to lay down some fairly serious coin. They come in a special package with extra creepage to the drain lead (smart).
I never thought of Stangenes as a possible vendor for an audio transformer, but they do other things that make that application look like a casual stroll in the park.
I just checked, and Ixys makes both IGBTs ans Mosfets at voltages up to 4kV - expect to pay...
Anyone tried the Hammond 1642SE in a BIG SE amp?Hide this!Advertise here!
Hammond 1650W GK Tubes / Valves 54 16th February 2016 02:08 AM
oiling a hammond B3 audiofan Instruments and Amps 10 9th June 2011 09:45 PM
Hammond PR20 Duke Davis Tubes / Valves 8 12th January 2009 08:27 PM
Hammond L-100 conversion rafaelblock Tubes / Valves 0 19th February 2008 06:16 PM
Hammond Transformers Gabevee Tubes / Valves 0 5th April 2004 03:47 PM
Copyright ©1999-2017 diyAudio
