| diyAudio Sponsor | ||
Does anyone have a suggestion for a pair of 300B tubes for Welborne DRD amps? I prefer liquidy midrange to bass/treble extension if this is an either/or. Also, price should be within reason (i.e., W.E.'s are too expensive.)
Tubes I have heard good things about are the TJ mesh plates, and some of the sophia electrics (these are perhaps the same tube?), as well as the KR audio and emissions labs. Also, any thoughts or suggestions on where to get them ?
http://www.ecpaudio.com |
#2 |
I have both TJ mesh and EH gold grid 300B's. They both sound differently but I like them both.
Johnny |
#3 |
when using relatively expensive Tubes anyway, then I´d opt for the best...which is without doubt the KR300B XLS. They are more expensive than other tubes, but on the other hand they´ll last min. 3-4 times longer because of their build-like-a-battleship-quality and has much more dynamic headroom than any other (20-25W against app. 8-10W from a mesh-type in SE mode). Don´t use mesh plate types. There is no good technical/sonical reason at all for the usage of a mesh instead of an massive plate (well ease of building and production costs are good reasons...but not for the end-user). Less stability, less wattage, less dynamics, less lifetime....more light (if You want that, get Yourself a proper lamp jauuu Calvin |
| Best place to get Shuguang 300B tubes | lowtherdream | Tubes / Valves | 15 | 7th May 2009 06:43 PM |
| Sourcing JJ 300B tubes | zigzagflux | Tubes / Valves | 3 | 24th May 2008 05:02 PM |
| PX25 tubes in a 300B Amp? | korneluk | Tubes / Valves | 1 | 27th February 2007 11:36 AM |
| DIY speakers for 300B suggestions?! | jvsb | Multi-Way | 19 | 20th May 2003 01:24 PM |
| WE 300B tubes. | Ignacio | Tubes / Valves | 3 | 4th August 2001 09:56 AM |
| Page generated in 0.07192 seconds (71.98% PHP - 28.02% MySQL) with 11 queries |
