diyAudio Sponsor
Old 2nd September 2005, 04:45 PM   #1
Lightbulb Differential input stage
Hi all, would like to ask if anyone out there could help me with a schematic or ideas for a differential input/pre-amp stage.
I can easily achieve this with op-amps but am toying with the idea of using valves, well, because I like them so mutch.
Many thanks,
Carl.
Old 2nd September 2005, 07:34 PM   #2
diyAudio Moderator Emeritus
ray_moth's Avatar
The attached is my EL34 triode-strapped PP amp which starts with a differential (LTP) splitter, using a pentode as current sink for the tail. If you build it you may have to experiment a bit with the bias network to get a useable range. I run the El34s at about 45mA but my particular tubes are el-cheapo so-called "Svetlana" (not winged C) and have unusually low transconductance.
Old 3rd September 2005, 03:35 AM   #3
hagtech's Avatar
Here's another one. It's the front end / driver for a power amp, but would work just fine as a differential linestage. It's a little odd in that it uses a dc supply from the output tube bias to power the current source on input. You could use a 6.3Vdc heater supply for your application. Or similar.
The current source is key to optimal operation here. It provides better ac balance for the outputs (plates), plus it offers input common mode rejection (small range).
jh
Old 3rd September 2005, 03:48 AM   #4
Steve Eddy's Avatar
Default Re: Differential input stage
Ideas? Here's an idea: Use a transformer. They make for one hell of a differential input stage in my opinion.
I like valves too, but I like trasnformers even more.
se
Old 3rd September 2005, 07:49 AM   #5
Thanks for the schema Ray, I'll give it a go, I've just built a test rig to play with circuits. I think I have those triodes in my box at home,
I like EL34'2 too, they are readily available here in ZA and more bang for your buck.
Cheers.
Old 3rd September 2005, 10:04 AM   #6
http://www.tubecad.com/2004/blog0008.htm
Old 3rd September 2005, 10:07 AM   #7
Thanks JH, looks like an interesting design on the whole, not sure if I can get the tubes, if not, I'll try the idea out with similar valves.
Best regards, cb
Old 3rd September 2005, 10:07 AM   #8
Thanks too to SE, I have been looking at Jensen's transformers and many others seem pleased with their results, worth a try if I can get my hands on one.
Best regards, cb
Old 3rd September 2005, 07:29 PM   #9
Steve Eddy's Avatar
Yeah, the Jensens are very good quality transformers and I've used them for over 10 years. However I've more recently found CineMag's transformers to be just as good in terms of quality but at prices significantly less than that of the Jensens.
se
JLH with a differential input stage mohan72 Solid State 46 10th September 2008 07:59 PM
Differential I/V stage? And RX input guzzler Digital Source 29 19th December 2006 05:32 PM
Adding a third input to a differential input stage? maudio Solid State 15 11th October 2006 02:16 AM
differential input stage xuesong Solid State 3 27th December 2004 02:08 PM
Page generated in 0.10270 seconds (77.79% PHP - 22.21% MySQL) with 11 queries
