diyAudio Sponsor
Old 2nd September 2005, 05:01 AM   #11
amperex is offline amperex  United States
Gary Primm CCS but replace the 12AX7 with Mil Spec 5751. It has a gain of 70 that should be plenty high enough for your application.
Some favorites are:
GE 5751 3-mica black plate (grey plates suck)
RCA Command series 5751 black plate
Sylvania 5751 black plate square getter
Old 2nd September 2005, 07:48 AM   #12
analog_sa's Avatar
well there is a slight problem...
Not really. I drive a 6S45 into a Lundahl 1660 from a TX102 and it sounds great. Not to mention that it saves a stage. Be ready to buy a dozen or so 6S45 if you want to match them though.
Monlithic transistor IC for input stage design? Bitrex Solid State 16 24th June 2009 01:23 AM
unusual design of input stage Kuzmenko Solid State 18 15th January 2007 09:22 PM
current bias j-fet input 2sk170 ,2sj74 at input stage YUTK Solid State 11 2nd June 2005 03:34 AM
input switching design for balanced line stage ijomojo Pass Labs 3 23rd January 2005 02:02 PM
LM6171 input stage design capslock Solid State 17 20th March 2002 03:49 PM
Page generated in 0.07124 seconds (66.45% PHP - 33.55% MySQL) with 10 queries
