| diyAudio Sponsor | ||
#12 |
My employer, FOX13 Television in Tampa operates the most powerful privately-owned Doppler Radar in the United States. 12.5 Gigawatts ERP.
The transmitter uses a Magnetron which is pulsed by a Hydrogen Thyratron.
Frank |
#13 |
That's enough for 10 flux-capacitors( and the remnant will probably support all ten of the support hardware ). When do you want to go?
cheers, Douglas
the Tnuctipun will return |
#14 | |
I guess we've slid off topic!
Brian |
#15 |
I wonder why no one has questioned the class-A claim in the thread-title so far - after so many posts.
Transmitters are often single-ended, that's true. But most of the time they are class-C. In applications where linearity is critical push-pull class AB is used. Regards Charles |
#16 |
I wouldn't take this thread’s title seriously at all. The William Johnson schematic looks like no RF amplifier I've ever seen.
But to continue with Johnson’s circuit: ARC used a variant in their MCP-33 moving coil head amp, except they drove the signal into the bottom cathode with the grid grounded. Looks like an interesting topology, although I never had a chance to hear an MCP-33. Has anyone here?
Brian |
#17 |
"I'm glad I don't live near that beast!"
Don't worry. The 26 foot radar dish is 250 feet in the air. There is side lobe absorption material inside the reflector. The beamwidth is (I believe) .1 degrees. The radar operates at 5.75GHz with a pulse rate of 250Hz. The radar doesn't even interfere with our 5.8GHz microwave receiving equipment which is located only 20 feet below the radar T/R dish.
Frank |
| amplifier picking up radio stations | nsxxtreme | Car Audio | 1 | 5th March 2009 03:23 AM |
| amplifier picking up radio stations | nsxxtreme | Solid State | 1 | 4th March 2009 04:40 PM |
| Page generated in 0.09005 seconds (74.59% PHP - 25.41% MySQL) with 11 queries |
