| diyAudio Sponsor | ||
#2 |
No, there is no B+3. The place marked B+3 should be B+2. All the other B+2 are correct.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#3 |
Sorry if I am being dense here.
So will both B+2 points in the PSU schematic connect to all three B+2 points in the amp? |
#4 |
Does someone actually know what the voltages at points B+1 and B+2 are?
Especially B+2 as a feed for the Hedge would be interesting: The constant current sink evaluates to about 8mA, thus the voltage drop across the 4k7 resistor between points B+1 and B+2 would be about 40 volts. It would be reasonable to assume about 400V at point B+1, thus B+2 would be at about 360V. But that would exceed the ECC88 ratings in that Hedge circuit: 8 mA across the 25k plate resistor gives a drop of 100V, thus 360V - 100V = 260V at upper tube plates. Assuming the least worst case scenario each tube section has to deal with 1/2 * 260V = 130V plate voltage which exceeds ECC88 specs a bit... So, again, does someone actually really know what the voltages at points B+1 and B+2 are? Tom
If in doubt, just measure. |
#5 | |
#6 |
RE: voltage versus max Va for ECC88, is this a stereo amp? If so, double the drop across the 4k7. Also, I'd expect the B+ to be under 400V given the DCR one might expect from a 10H inductor.
130V is within the max Va spec, but it is admittedly pushing things. edit: Using a PSUD sim, I get about 390V B+1 for a monoblock, 375V for a stereo pair running off a single supply
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#7 | |
Yes. The "B+2 point" that is the lower one, coming off the filament supply isn't actually "B+2" at all, it should have an arrow that indicates that it connects TO the "B+2" point. The purpose is to inject 6.3vac antiphase (one would hope) back into the B+ that runs the input stage - thus cancelling the hum component. I am guessing this is the idea. I'd just switch to DC regulated filaments for these indirectly heated tubes and eliminate the problem at the source. Much better idea. There are a number of other 'issues' with this circuit. I don't see any application of fixed bias here. Imho you'll get rather fat and sloppy sound by using self bias and setting the tubes up on top of large electrolytic caps in the cathode. At least bypass them with a largish polypropylene? Also, the phase inversion balance is likely to be somewhat off if you merely ground the (-) input for single ended input. There are some circuits that provide a solution for this, some are in the Radiotron Designer's Handbook as well as other places. Mostly it is a change to what you do with the (-) input, although there are some things that can be done with the long tail pair's cathode side.... At least I think that's how it might go. _-_-bear
_-_-bear http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. -- |
#8 | |
#9 | |||
Well,
I am also working on "my" version of the pp1, so the questions discussed here have my full interest... Quote:
And, one final thing, although it is a bit OT for this thread: In solid state design I always used to build fully separate power supplies for both channels, perhaps drawing current from the same transformer, but separate rectification and filtering. How do I handle this in tube circuits? a) one PS for both channels b) one transformer, one rectification, separate filtering c) one transformer winding, separate rectification and filtering or d) two separate PS Sorry, so many questions... Gladly looking forward to your answers Greetings Andreas |
#10 | ||||
diyAudio Moderator Emeritus
| Help from Allen Wright SuperReg owner | pchw | Tubes / Valves | 3 | 7th December 2008 07:57 PM |
| Allen Wright Superreg manual | djmike | Tubes / Valves | 3 | 25th September 2008 02:48 PM |
| For sale: One complete Set of Allen Wright Mod for Sony SCD-1 | Elso Kwak | Swap Meet | 7 | 9th July 2004 04:28 AM |
| Talbot Wright's Williamson mod (Heathkit W3-AM) | vintage_dog | Tubes / Valves | 0 | 11th April 2004 12:17 PM |
| Page generated in 0.13225 seconds (80.94% PHP - 19.06% MySQL) with 10 queries |
