diyAudio Sponsor
Closed Thread
Old 25th August 2005, 03:59 PM   #1
Account Disabled
Default is 845 better than 211 tube amplifier ?
Old 25th August 2005, 04:10 PM   #2
analog_sa's Avatar
No, it's different.
Old 25th August 2005, 06:35 PM   #3
edl is offline edl  Hungary
edl's Avatar
IMHO "hifitube" and "okhifi" is the same person, and he is a TROLL...
Very strange topics/questions...
Is SE-A better then PP? There is no answer!
Old 25th August 2005, 08:42 PM   #4
analog_sa's Avatar
Indeed. But the answer is simple - a PP 845 will eat a SET 211 for breakfast
Old 26th August 2005, 02:07 AM   #5
tubelab.com's Avatar
Here again the two tubes sound different. Your choice depends on your ears listen to both and chose what you like. It is possible to build an amp that will work with both tubes. I have done this and I have listened to both tubes ( new Chinese, and old RCA) and I prefer the 845. You may prefer the 211. I can't tell you what you like. I like loud rock music. Do you?
http://www.tubelab.com/845SE.htm
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Closed Thread
Tube SE amplifier with 6P3S (russian tube) danzup Tubes / Valves 46 12th April 2012 08:35 PM
Page generated in 0.07021 seconds (71.37% PHP - 28.63% MySQL) with 11 queries
