| diyAudio Sponsor | ||
What is the proper pin 4,5,9, connections to run a 5687 at 6.2 volts?
My PT has a 6.2 Vac center tapped filament supply and plenty amps. Is it, pin 4 & 5 shorted on one leg and pin 9 on the other?.etc I just want to power up this experiment, I don't need regulation, or 12 V DC recitified now. thanks, dr._sleep P.S. I should know this...so shoot me. |
#2 | |
almost... 5687 has a different pinout than 12A_7 types; the heater CT is on pin 8 (and section 1 plate is 9 and cathode is 6). but otherwise, yes, just connect 4 & 5 together and put the 6.3V between them and 8. |
#3 |
Just shoot me,
Thanks very much, problem solved, dr._sleep |
| 12AX7 heater filament resistance | Ipanema | Tubes / Valves | 25 | 2nd July 2009 06:12 PM |
| Is 6V DC too low for heater filament? | Sunsun22 | Tubes / Valves | 8 | 29th December 2008 07:45 AM |
| Hum free 5687 AC filament supply, is it possable ? | Shoog | Tubes / Valves | 17 | 13th January 2005 09:26 PM |
| grounding heater/filament center | metebalci | Tubes / Valves | 6 | 27th March 2004 08:24 AM |
| 5687 filament question | tone | Tubes / Valves | 47 | 22nd January 2003 02:20 PM |
| Page generated in 0.07143 seconds (69.62% PHP - 30.38% MySQL) with 10 queries |
