12AX7, EL34 or 6L6 design wanted
Old 10th September 2005, 12:37 PM   #21
Fiat1 is offline Fiat1
Thanks for the reply! That would be great if you could help out with a diagram. If I were to run it at 250v B+ what sort of current would it draw?
Old 10th September 2005, 12:53 PM   #22
Johan Potgieter is offline Johan Potgieter  South Africa
About 140 - 150mA in class-A - but I don't want to hi-jack Aletheian's design. As said, will return after week-end if necessary.
Old 13th September 2005, 07:35 PM   #23
aletheian is offline aletheian  United States
aletheian's Avatar
Dude... hijack away. I drew that amp up in a few minutes, so tweak as neccessary.
As far as the ecc's, the voltage that shows up on the plate will drop across the Rp. I have run cathode followers too that tied the plates of a 12ax7 directly to a 400+v supply, and they lived long happy (albeit hot) lives
12AX7, EL34 or 6L6 design wantedHide this!Advertise here!
Wanted. Simple EL34 Push Pull Design jack firebrace Tubes / Valves 51 29th July 2013 01:47 AM
Tubes for Sale - Link to List 12AX7,5AR4,6550,EL34 and More baileyler Vendor's Bazaar 3 22nd April 2008 02:20 PM
EL34 SE triode mode A class sch wanted trancy Tubes / Valves 14 10th January 2008 11:16 AM
PP EL34 circuit wanted Norris Wilson Tubes / Valves 3 9th August 2007 12:29 PM
6L6GC/EL34 SE Stereo Design bartr0n Tubes / Valves 25 16th September 2003 07:03 PM
