diyAudio Sponsor
Old 23rd August 2005, 02:50 AM   #1
DJNUBZ is offline DJNUBZ  United States
Default Any one tried to use subminiature for input tubes?
Just wondering if anyone has tried this before. Seeing as they were some of the last tubes designed and were supposedly well made I figgure they may be an untaped resourse.
Old 23rd August 2005, 04:12 AM   #2
nuvistor's Avatar
Do you have any? The types with glass envelopes and wire pins aren't all that common. 6111 is mu=20, 6112 is mu=70. I have some used 6111s that I haven't fired up yet.
If you mean nuvistors, like 6CW4 mu=65, 7586 mu=35, I used to find these at hamfests before eBay, not so much any more. They are rather microphonic, ring at about 10kHz.
For low-level input, good 12AX7 or 12AY7 are by and large not microphonic, low flicker noise, well suited to phono input. Nuvistors are probably OK for line level but I'm wary of their microphony
Old 23rd August 2005, 10:05 AM   #3
FWIW, the 6DS4, with its low noise and high gain, has me thinking about phono stage service. Putting a drop of silicone or acrylic caulking on top of the envelope might tame the microphonics.
Eli D.
Old 23rd August 2005, 04:34 PM   #4
RE 604 is offline RE 604  Germany
RE 604's Avatar
Hello ,
suminiature tubes ? Yes , look here :
and here is the complete projekt :
http://www.ak-tubes.de/Vorverstaerke...ube_preamp.htm
and another little amp is here :
http://www.roehrentechnik.de/html/kolibri.html
Regards , Alex .
No reason to get excited : Jimi Hendrix .
Old 23rd August 2005, 07:35 PM   #5
Tubes4e4's Avatar
Hi Alex,
Originally posted by RE 604
Hello ,
K³\/\/L wiring / parts placement technique
That reminds me I have a few TFK 5676 in the drawer
Tom
If in doubt, just measure.
Old 23rd August 2005, 08:40 PM   #6
SY's Avatar
Those are the Tektronix ceramic terminal strips? If so, how did you mount them? The ones I have are secured to the original Tek chassis by a little plastic o-ring which does not seem to be removable without destroying it.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 23rd August 2005, 09:50 PM   #7
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Yes , look here:
That's a lovely construction.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 23rd August 2005, 11:16 PM   #8
RE 604's Avatar
Hello Sy ,
it it very easy to remove this Tektronix terminals , they are only pressed in their plastic holders . You need only a screwdriver to pull them "carefully" out . I had no problems to do this .
@EC8010
Thank you for your nice comment for my little preamp , I had great fun , building this , but the pcb version is easier to build and works also very well .
Regards , Alex .
Old 23rd August 2005, 11:27 PM   #9
SY's Avatar
Were you able to re-use the little plastic o-rings?
Old 24th August 2005, 12:58 AM   #10
wa2ise is offline wa2ise  United States
wa2ise's Avatar
Submini's work well. They are really not different than regular tubes, just smaller and cute looking
Look at my web page using subminis in radios and in CD players as input tubes
Only ones I've seen as microphonic were filament DHT types. Indirectly heated subminis are designed to take a beating (like in rockets and warheads and such). Well, not literally but they are designed for high G forces.
How to test a subminiature tube dayveshome Tubes / Valves 4 23rd August 2009 03:16 AM
Subminiature sockets coresta Tubes / Valves 23 5th December 2008 09:03 PM
Input Tubes? d1983 Tubes / Valves 7 1st June 2007 05:11 AM
input tubes using 6922? jarthel Tubes / Valves 7 23rd March 2007 11:07 AM
subminiature tube suggestion dsavitsk Tubes / Valves 13 22nd December 2005 06:09 PM
Page generated in 0.10544 seconds (77.45% PHP - 22.55% MySQL) with 11 queries
