| diyAudio Sponsor | ||
this is my first post in the Diyaudio forum, and I'd like to ask you for a little brainstorming A few weeks ago I got hold of the AudioValve PCL805 headphone amplifier, and now i seem to be infected with the tube virus Well, here are my rough ideas, i would like to hear your suggestions, if possible accompanied by schematics - PP-Design operating in Class A - Triode output stage - "common" tubes, please no "exotics" which are difficult to replace - 10 to 20 watts output power per channel - "common" output transformer, something i can buy instead of building it myself - and, i would like to do completely without semiconductors, so i need a rectifier tube vor the anode voltage, and AC heating for all tubes Well, i'm looking forward to your suggestions, and sorry for my English Greetings, Andreas |
#2 |
diyAudio Moderator Emeritus
Something PP EL34 or PP EL84 comes to mind.
Here is a good start for a schematic. ![]() sorry...has semiconductors in there...but.... Plenty of choice for standard output transformers. What preamplifier do you have? (Bride of Zen? what is the gain of that preamp?) What speakers do you have? How big is your room? Regards, Bas ps..your english is perfect. |
#3 |
#4 |
Hi Bas,
no separate Preamp, so a preamp stage needs to be included, in german its called a "Vollverstärker" but I can't remember the english word for this. Speakers are selfmade transmission lines, should make about 90dB... As stated before, I have absolutely no experience in designing tube circuits, up to now only repaired or upgraded existing ones... So I would be glad if, after some discussion, this thread might give some reliable, practically tested schematics. I think i know the basics about tubes and operation modes, but I shurely do not have the experience to turn a "standard layout" or principle into a well working amplifier. Just don't know the "dirty tricks" One thing I forgot in my list above: - I don't want to say that I dislike the "typical" tube sound, absolutely not! But in my opinion an amplifier should also have measurable qualities. A frequency response of about 25Hz-20kHz or better should be possible, and THD should be reasonably low... Many expectations, I know, hope it isn't tooo much Greetings Andreas |
#5 | |
Oeps ....both schematics I posted need a seperate preamp
[EDIT]...looks like Poinz's amp need not have a seperate preamp. Quote:
#6 | |
Been thinking about a 6550 version (with proper chasis' this time) to drive my KEF 104/2's. I have all the parts here, but little time at the moment.... |
#7 |
For a first start a ecl82 push pull amp could be a good choice. But I suppose the Allen Wright amp is soundswize better.
Question: Why the Lundahl iron ? Suggestion: the AW amp with 807 tubes. |
#8 |
Your countryman Huber had an interesting EL84 on the web (now disappeared (?)).
Could anybody comment on this design ? Did anybody build or heard it ? |
#9 | ||
#10 |
I thought that your suggestion had to do with something Allen Wright said on the tube asylum:
"In my experience, P-P amps need the standing current in the OP tubes to be VERY closely matched - or you will have a DC component in the OPT that really limits the fine detail µdynamics of the whole amp and causes it to sound closed down and lost. Some OPTs are more sensitive to this than others: toroidals are the worst and cannot accept more than a mA before losing quality bigtime - 'normal' (non airgapped) P-P OPTs should be balanced to a mA if possible to be at their best, but Lundahls (which have a airgap even in their P-P OPTs) can be off a couple of mA without any noticiable loss." It is not a secret that Allen has his PP-1c amp updated with a ccs under the cathodes of the outputtubes. In this way the outputstage is perfectly balanced and I think there is not a specific need for a Lundahl. You could easly use a famous vintage opt I suppose, or a cheaper one from Asia, or whatever quality-opt from own neighbourhood. |
| Amplifier suggestions for EPA OPT please | greenvalve | Tubes / Valves | 17 | 23rd April 2009 03:37 AM |
| Tube ID and suggestions | Grathan | Tubes / Valves | 3 | 8th February 2009 11:56 PM |
| Tube Amp Kit Suggestions | baltimoreblues | Tubes / Valves | 20 | 13th July 2008 04:53 PM |
| Tube Suggestions | dsavitsk | Tubes / Valves | 13 | 4th August 2006 08:22 PM |
| Suggestions for top bal out tube pre? | protos | Tubes / Valves | 5 | 26th February 2003 03:20 PM |
| Page generated in 0.13106 seconds (84.66% PHP - 15.34% MySQL) with 11 queries |
