Question : pentode ccs schematic ?
Old 4th September 2005, 04:41 PM   #11
00940 is offline 00940  Belgium
00940's Avatar
Eli Duttman : I'm sorry, I've been out of town for a little while. Thanks a lot for your comments.
Would this schematic match your description ?
All that is excessive is insignificant. Talleyrand
Old 12th September 2005, 07:00 PM   #12
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default Re: Question : pentode ccs schematic ?
Originally posted by 00940
Long time ago, EC8010 suggested that : "a pair of PCF80 would make a very nice line stage/buffer. Use the triode section as a cathode follower, and sit it on the pentode section used as a constant current sink. Use a 300mA DC constant current regulated heater supply, and you'd have something with performance completely out of proportion to price."
Sorry about the delay (took me a while to find an envelope to draw it on). Here it is:
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 12th September 2005, 10:32 PM   #13
Bandersnatch is offline Bandersnatch  United States
I would do it the other way. Pentode as the signal input tube. Triode's cathode to negative rail through the current setting R. Triode's grid to the negative rail.
The triode will be a fine load for the pentode's cathode, and the pentode's plate will be more tolerant of B+ ripple. Pentode's anode to B+, g2 to one end of a 100k resistor, and B+ to the other. 0.5 uF to 1 uF cap between g2 and the pentode's cathode.
cheers,
Douglas
the Tnuctipun will return
Old 12th September 2005, 10:49 PM   #14
On Hiatus
SY's Avatar
That's not as advantageous as it might seem. The ripple on a triode plate will be attenuated in the CF output by a factor of mu (20 in this case). Whatever ripple is present on the screen will be passed unattenuated. Now, you do have an RC rolloff, but with the values you give, the attenuation isn't any better than mu anyway. Sure, you could go up another factor of 10 on the cap, but that increases size and cost.
It's pretty easy (see my preamp article) to get the ripple down to ridiculously low levels, so why not put the big cap toward that end? That way, one can take advantage of the much superior CCS characteristics of a pentode plate.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 12th September 2005, 11:15 PM   #15
ALright, I pulled the sheet on this beastie. It isn't a very good tube for the use you all propose. Two EF184 will cost $5USD and they have 15 mA/V transconductance. That amounts to ~50R output Z for a cathode follower. They have 90kOhm plate Z so they make fine sink-CCS too.
If I were going to the trouble of cutting a bunch of holes and assembling a proper power supply, that's the way I'd do it. Or one could take Sy's route and rig the input valve as a triode...
cheers,
Douglas
Old 13th September 2005, 08:13 AM   #16
EC8010's Avatar
Agreed, EF184 is a very nice valve indeed and if you're going to gp to the trouble of nice metalwork specifically for a cathode follower line stage, then it's a much better choice, However, if you need a triode cathode follower with pentode CCS in an existing piece of equipment and have room to bash a single hole with not much HT, then the PCF80 could work very nicely.
I take the point about ripple rejection and g2. My back of the envelope sketch used the minimum voltage possible and the curves were for g2 = 170V, so I just took g2 to the HT. A better idea would be to do some tests with a lower g2, allowing RC smoothing to g2.
Old 13th September 2005, 10:20 AM   #17
and the sad thing is those ECF80 come at 7 per Tektronix 502, so I have a small sack of them. All European Amperex. The pentode section is really a 3-grid pentode, and the triode section is like twice the gm of a 6SN7.
I would suggest an even more complex arrangement, involving some ~100V voltage references and stack the pentode on top of the triode, cascode style. This still leaves one with the trouble of a cathode sink...
cheers,
Douglas
Old 14th September 2005, 09:57 AM   #18
sunrise is offline sunrise
sunrise's Avatar
Send a message via ICQ to sunrise
Default 00940 mail
Sorry this is off topic.....
00940
Dear Sir - I could not email You - this is why
I am sending You this email..... Do You know where to find RKV headphone schematic?
Best regards
sunny
when you burn it - burn it good
Old 22nd January 2007, 12:30 PM   #19
soundbrigade is offline soundbrigade  Sweden
soundbrigade's Avatar
Send a message via MSN to soundbrigade
Quick in - quick out ....
I've had Pete Millett's original article in AudioXpress (low mu triode CSS preamp) for breakfast (well litterature to my tea and cereals) for severeal days, and though the design is flawless I still wanted to make some changes.
The 6AS7-EL34-duo is a bit too strong and consumes a little too much current for the heaters so I started thinking of other duos that could do the trick but with less heat. What I came up with was the 12B4A-triode and an EL84, or possible an 6AQ5 as CSS. Or using the Russian 6N6P (6H30P, 5687, E182CC) as triode and the 6AQ5/6BQ5 for pentode.
Would that be reasonable if you still want some current capability?
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 17th November 2015, 10:34 PM   #20
Interference is offline Interference  Italy
Hello, I'd like to try this little project as I have a couple of spare PCF80.
I have a couple of questions about the schematics posted:
- is there any resistor between B+ and pentode G2?
- is there any resistor between triode cathode and pentode anode?
Plus: what would be a good choice for a B+ power supply in this case? I have seen several designs (i.e.: A New High-Voltage Regulator) but still undecided on which to choose.
Thanks in advance!
Question : pentode ccs schematic ?Hide this!Advertise here!
Pentode grid question... Brouilly Tubes / Valves 10 28th March 2009 07:02 PM
Transformer Coupled Pentode Question dsavitsk Tubes / Valves 2 12th February 2008 07:47 AM
Pentode/triode switch question Stormo Tubes / Valves 6 12th October 2007 08:05 PM
A small no-fuss pentode/pentode SE amp Tubes4e4 Tubes / Valves 13 1st January 2006 05:16 AM
6216 beam pentode question arnoldc Tubes / Valves 6 17th February 2004 12:06 PM
