diyAudio Sponsor
Old 17th August 2005, 07:56 AM   #1
Default right capacitor value?
In the simulation of the schematic I join to this message (gomez) not made by me, It appears the coupling capacitor to be of 2,2uF.
This capacitor value makes not possible to the output impedence to be very low at lower frequencies.
As you can see the out Z will be around 100 Ohm, only until 1 Khz.
Than will increase.
Now: HOW DO I HAVE TO CALCULATE THE EXACT VALUE OF THE COUPLING CAPACITOR IN THE SAME CIRCUIT SHOWN, TO HAVE THAT OUT IMPEDENCE (around 100 OHM) UNTIL THE LOWER FREQUENCIES (LET'S SAY 20 Hz)?
Thank you for helping. G.M.
Old 17th August 2005, 09:36 AM   #2
diyAudio Moderator Emeritus
ray_moth's Avatar
Reactance is inversely proportional to capacitance. To get the same reactance at 20Hz as the 2.2uF cap has at 1kHz, you need a cap of 2.2*1000/20 = 110uF.
Old 18th August 2005, 10:08 AM   #3
Thank you very much!
It was so simple, that I couldn't find the solution!
Old 12th March 2006, 03:36 PM   #4
Default ...still help!
Hi!
If, for example:
- we have a BJT buffer (power amplifier of 200 watts max, with no voltage gain) with approx 10KOhm input impedance (in the schematic attached to the first post we drew it with a simple resistor)
- I want to drive this buffer stage with the gomez drew as above,
- I want an hi control also on low frequencies
using a coupling capacitor of 1-2-3... or 10 uF (max) causes a very high output impedence of the Voltage stage, exactly where and when instead I need big "control".
The possible solutions:
- can I use a coupling capacitor of around 100 uF to have same impedance at 20 Hz?
- Don't you think using this big capacitor will worsen the sound, especially on mid-hi frequencies?
What kind of solution would you recommend (or use) in situation like this?
Thank you very much
Old 12th March 2006, 04:36 PM   #5
kevinkr's Avatar
I think you are confusing pre-amplifier source impedance with power amplifier load (speaker) control or damping factor. Your amplifier exerts control over the speaker you are driving independent of the input source Z, it doesn't care what the source impedance is at its input terminals within reason as long as it is reasonably constant and a small fraction of the input impedance. According to a quick calculation you would be less than -0.5dB down @ 20Hz with a 2.2uF, note that large value high voltage film caps are very expensive, so this might be an ok compromise, certainly 4.7uF would be better, rolloff would be less than 0.2dB at 20Hz in this case. I would not go over 10uF in any case.
Another thing to consider is that larger film caps do not sound as good as smaller ones due to increased inductance, DA, and other variables and should probably also be bypassed by a much smaller higher quality film cap.
Something else to mention is that if you are using a solid state amplifier you must wait to turn it on until no more charging current is flowing in that large output coupling cap. I recommend a muting relay to short the output side of that cap to ground for at least 30 seconds after the pre-amp filaments and supply are FULLY warmed up in order to reduce dc at the input of your amplifier to 0. Failure to do this may result in blown output devices in your amplifier (possibly blown input transistors or ics as well) and fried voice coils in your woofers..
edit: add a thought or two
www.kta-hifi.net
Old 12th March 2006, 06:26 PM   #6
Hello, and thank you for your advices!!
My doubts come from the simulation in "gomez.gif" (1st post), when you can see the output impedance increase a lot at lower frequencies.
And this is also when the bjt stage input impedance remain the same (let say 10 Kohm).
So it is true the low bandwith is -0.5 dB at 20 Hz, with a coupling cap of 2,2 uF, but it is also true that if the driving impedence of the BJT stage increase at 1Kohm or more, It will lack especially the bass controls.
We have the same effect if we use a Tube voltage stage with 2 Kohm output impedence (like 6Sn7 SRPP) or the same stage with, for example 6H30 (300 Ohm output impedence).
I want to say that is clearly listened the differencens IN LOW FREQUENCY CONTROLS between the two stages (I mean better 6H30 stage) ALTHOUGH both stage have 2,2 uF coupling cap and -0.5 dB at 20 Hz!
What do you think?
Thanks!!
Old 12th March 2006, 06:35 PM   #7
** So it is true the low bandwith is -0.5 dB at 20 Hz, with a coupling cap of 2,2 uF, but it is also true that if the driving impedence of the BJT stage increase at 1Kohm or more, It will lack especially the bass controls. **
Sorry, maybe it is not enough clear: I want to say:
It is true that the low bandwith is -0.5 dB at 20 Hz, with a coupling cap of 2,2 uF, but it is also true that
if the driving (VAS) impedence that the BJT stage sees, for istance, at 40 Hz, has increased at 1Kohm (or more... see the graph above), it will be (IT IS!!) very audible the consequent lack in the bass.
Old 12th March 2006, 11:17 PM   #8
kevinkr's Avatar
Well that is the implication of the falling response below (or sometimes even above ) the corner frequency, however it is not a great idea to use very large coupling caps with tube pre-amplifiers operating into low input impedance solid state amplifiers - this is a recipe for disaster. I did mention the turn on issue and totally forgot to mention the turn off issue which is of the same magnitude but opposite sign, either way it won't matter much if large amounts of dc current flow through your speaker voice coils.
Since you are so (rightly) concerned about the driving point impedance I would recommend you consider a really good line output transformer for your application - suitably sized & designed you will get great bass response and a very uniform source impedance across the entire audio spectrum. You can easily get source impedances of a few hundred ohms or less, particularly if you use something like 6H30 to drive it.
Also no dc issue to be concerned about either.
If you were to use a CCS or choke and parafeed configuration there are many off the shelf transformers you can use.
Bartolucci should be able to help you out with this. (Both parafeed and conventional SE line stage transformers.)
www.kta-hifi.net
Best PS capacitor RFENG Parts 3 19th January 2008 02:44 PM
what capacitor is this? abiedoodles Parts 10 12th December 2007 07:11 PM
Capacitor Help MorePower7701 Solid State 8 25th July 2007 06:41 PM
Capacitor esl dhole Pass Labs 1 23rd April 2005 02:18 PM
Capacitor or not? future Parts 2 24th June 2003 11:10 PM
Page generated in 0.10052 seconds (82.54% PHP - 17.46% MySQL) with 11 queries
