diyAudio Sponsor
Old 6th November 2006, 04:18 AM   #341
Sheldon is offline Sheldon  United States
Originally posted by Kofi Annan
More updates...
I changed the makeup of the NFB circuit today. The cathode resistor is now around 700R and the feedback resistor is down from 8.4K to about 4.6K with a 470pF mica bypass cap. I think this one's the winner.
It sounds natural and not as stifled as the original configuration and it really needed more correction than I had going with the 8.4K NFB resistor.
I'll play it for a week and see how it sounds but I had a little... uh... accident while I was soldering.
I guess I was manhandling the third pin (cathode) on one of the E88CCs and it snapped off. I managed go get it back in and I soldered it back into the socket, but I'm guessing a responsible person would remove the entire socket and engage in a do over.
Right?
Kofi?
If you are talking about the contact that is in the socket, most of the different types are removeable. Simply replace the broken one with a good one from a spare socket. If you inspect the spare closely, it should be fairly obvious how they are retained in the socket, and therefore how they can be carefully removed.
Sheldon
Kofi Annan in: "Kofi's Living Room" Kofi Annan Full Range 5 25th May 2008 06:19 PM
Kofi Annan in: "Kofi Makes a 300b DRD... and You Get to Help!" Kofi Annan Tubes / Valves 135 15th October 2007 07:15 AM
Kofi Annan in: "300beee!" or "Kofi Gets a Toy" Kofi Annan Tubes / Valves 125 25th August 2006 04:39 AM
Page generated in 0.08111 seconds (69.48% PHP - 30.52% MySQL) with 11 queries
