| diyAudio Sponsor | ||
#111 | ||
Ay yay yay yay YAY!!! Holy cow. I know that it was a lot of work to post this, but there's no way I'll get this. Let me explain: As a child my mother would say, "Kofi, make sure you use a current balance resistor for this project". I'd look at her blankly and she'd say, "Kofi, you can identify the cathode path, can't you?". Then she'd pause and say, "Kofi, your fly is open again". I love my Mom and all, she's a great girl. Possibly the greatest representation of her love for me was and is her realization of the concept that I'm kind of a dumbass. Please, please don't take this the wrong way. Its not you, its me. Well, actually, it may be you. You just haven't had enough experience with my magnitude of dumb-assedness. Honestly, and without invoking any sarcasm, I know that this is helpful. Its just that my level of understanding could not possibly fit on the same graph as yours. On the other hand, if we tried to graph a representation of the chasm that exists between my comprehension and yours, we may actually wind up creating a mathematical concept of the infinite. Maybe that would be bad, though. We may inadvertently deprive aspiring scientists in their junior year at MIT a chance at solving a quantum puzzle akin to Fermat's Last Theorem, a potential "A" in Quantum Mechanics III and a shot at a lucrative defense contract with the US gover... Uhh... BAD! BAD! BAD!!! Quote:
OK, so should the choke be in series with the voltage and the cap be grounded? Me like easy. Kofi |
#112 | |
Sheldon |
#113 | |
Joel |
#114 |
There's really no need to regulate the HV for that design- it's nearly in class A. If I were to build a regulator, I would use a heavy-duty version of the Maida or, at the expense of more expense, the Curcio reg. But Mr. Jones seems quite content with a plain vanilla LC filter for the output stage. The input stage regulator will provide superior decoupling compared with the passive that Joel suggests, but his passive would no doubt work fine too.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#115 | |
Woo hoo! Kofi |
#116 |
Resurrecting this old post...
I was on the path toward a 300b (see here), but budget constraints will likely push this project into 1Q 2007. Given that, I think I can still whip up this little neato Bevois Valley push-pull job, but I'm looking for a simple solution for the HV regulator that Morgan Jones recommends in his circuit. I think I need 285V regulated for HT and the screen supply and I thought that maybe the Supertex LR8 would do. It looks like you can set it up just like an LM317, but it will take an input from 12V to 450V and output 1.2V to 440V. Plus it's called a Supertex. So, thoughts on a Supertex-Regulated Bevois Valley EL84? Hurry up and respond-- I'm going to be tied up with this North Korea missile test thingee soon. Kofi |
#117 | |
Never used this one but I have a question; is 20mA enough current? It appears that is the output current limit.
--Sherman |
#118 | ||
Well, I'm back to searching for an easy-to-implement regulator solution. Any thoughts one this thingee? Any other easy HT regulator would be OK-- I just need to be taken a bit further down the path here. Or.. hey, remember this old tune?: Quote:
Kofi |
#119 |
How about a regulator per tube in true diy overkill?
If I had easy access to those regs I would get a few for screen regs myself.
None of us are leaving this world alive. Enjoy it responsibly as you may. |
#120 | |
Cheapest and easy is a couple of RC sections - just use PSUD (FREE) to play with values to get the right voltage and low ripple. Next cheapest and also easy is Joel's suggestion - again play with PSUD (see the pattern?). Or try Jone's two transistor regulator. Pretty cheap. Trim voltage by adjusting the divider resistors to the base of the bottom transistor (you do have the book, right?). Or buy the Welborne regulator. Not as cheap, and you don't have to read anything except how to hook it up, but you won't learn as much. Easy though, and will probably work quite well. Or one of SY's favorites the Maida (look it up on the National Semi site, or see this: TIP50 + LM317 High Voltage Regulator). Or? Your call. Sheldon edit: You only need about 17mA per side, so one of the Supertex jobs per side should do it, if they are otherwise suitable (I didn't check). I also did a quick run on PSUD. The HT supply has only about 10mV ripple to the power tubes. One RC section with a resistor of about 1.5-2k and a 47uf cap would give about the right voltage drop and ripple of well under 1mV. You could easily split this into two sections of 3-4k with 22uf cap. Many other combos will work too. |
| Kofi Annan in: "Kofi's Living Room" | Kofi Annan | Full Range | 5 | 25th May 2008 06:19 PM |
| Kofi Annan in: "Kofi Makes a 300b DRD... and You Get to Help!" | Kofi Annan | Tubes / Valves | 135 | 15th October 2007 07:15 AM |
| Kofi Annan in: "300beee!" or "Kofi Gets a Toy" | Kofi Annan | Tubes / Valves | 125 | 25th August 2006 04:39 AM |
| Page generated in 7.56909 seconds (2.39% PHP - 97.61% MySQL) with 11 queries |
