diyAudio Sponsor
Old 14th August 2005, 02:35 PM   #1
JDeV is offline JDeV  South Africa
Default EF91 Line Stage questions
I recently got hold of 5 new Mullard EF91 valves and want to know:
1) Is it a good valve to use for Hi-Fi quality projects?
2) Are there any good line stage circuits,using this valve, that I may copy?
3) Can anybody design a nice line stage or buffer, using this valve - if it is worth to do?
Thanx for all assistance
"Be carefull who's advice you buy, but be patient with those who supply it."
From Baz Luhrmann's - Everybody’s Free (To Wear Sunscreen)
Old 14th August 2005, 07:01 PM   #2
kopite is offline kopite  New Zealand
Probably not as this valve is a pentode and usually used in IF stages.
The EF94 (6AU6) is a similar valve and can be wired as a very good triode.
You may want to have a look at this.
Old 14th August 2005, 10:26 PM   #3
EF91 has a very high mu (70) in triode connection, which isn't desirable unless you want to use feedback (unnecessary in a line stage). I haven't seen any triode-ct curves, but it seems likely it would make a fair (1st) voltage amplification stage, as in a power amp. The plate resistance will be fairly low trioded (ca 10k), which is nice. But for line stage VA, no. If you're going to include a cathode follower on the output of the line stage, however, the EF91 ought to be about as good as anything in this function. Output impedance ca 150 ohm, and the high mu won't hurt linearity either (due to the 100 % degenerative FB of a CF). So don't throw them away! They also make good constant-current sources (ref. M. Jones' Valve Amplifiers). Not sure which op point might suit line stage CF use, but guessing 120-150 Vak and 5-8 mA or so (trioded, that is).
Morgan
Old 15th August 2005, 02:40 PM   #4
I found this article but can not see the relevant schematics. Can somebody maybe re-draw them?
http://members.lycos.co.uk/griffonco...line_stage.htm
Thanx to all.
Old 16th August 2005, 01:59 AM   #5
The schematic seems to be missing from the page. But there is an e-mail address on the index page. Maybe you could write the author and inform about the problem (or just ask for the schematic)?
griffon 'at' ntlworld 'dot' com
Do you need just a cathode-follower buffer (unity gain)?
I don't have access to a server to upload to, but if you write me, I
could probably draw something that might work with an EF91.
morgamp1 'at' yahoo 'dot' se
Morgan
Old 16th August 2005, 04:47 AM   #6
hacknet is offline hacknet  Singapore
i`ve seen tons of mullard ef91s at a local surplus store too... i had a look at the curves and they don`t look too linear on top of that i have doubts about the microphonics. am i wrong? i`m think about them in a phonostage. arn`t these 70mu valves built for stages like these?
Old 16th August 2005, 06:54 AM   #7
diyAudio Moderator Emeritus
ray_moth's Avatar
The EF91 was intended for RF and was used in the thousands 50+ years ago, including in some early computers. It is not a partricularly good tube for audio. Used as a pentode, it will be noisy. It also suffers from microphonics. However, as already stated, it can probably do duty as a CCS or CF.
Which DHT for Line stage? andyjevans Tubes / Valves 15 26th March 2009 01:10 PM
Aikido line stage - plus phono line stage cjkpkg Tubes / Valves 1 22nd November 2008 09:50 PM
Questions about this line stage eapavant Tubes / Valves 4 7th September 2006 12:35 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
#26 line stage help Original Burnedfingers Tubes / Valves 4 9th July 2004 10:56 AM
Page generated in 0.09853 seconds (74.81% PHP - 25.19% MySQL) with 10 queries
