diyAudio Sponsor
Old 11th August 2005, 10:29 PM   #1
Account Disabled
Default Power Resistor Smoking on HF-81
I just changed all the caps and out of tolerance resistors and now my Eico HF-81 amp starts smoking from the 10w resistor and one of the rectifier tubes sparks. I took out the transformers to repaint them. If someone could help me that would be great.
Old 11th August 2005, 11:07 PM   #2
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Is a power supply electrolytic connected the wrong way round?
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 11th August 2005, 11:19 PM   #3
Account Disabled
They are connected in the right way. It only started doing this after I resoldered the transformers wires back into place. I don't know whats going on. Thanks for your help.
Old 11th August 2005, 11:28 PM   #4
EC8010's Avatar
Damaged insulation on a transformer?
Old 11th August 2005, 11:30 PM   #5
karma is offline karma  Canada
karma's Avatar
i have had the same problem in the past removing old iron.
best thing to do is to tape it off and paint it. looks as good as removing it. and its faster
Old 11th August 2005, 11:31 PM   #6
What kind of paint? Are the coils exposed? Are you 100% certain it was reconnected correctly?
Old 12th August 2005, 12:16 AM   #7
Account Disabled
Okay I inspected the amp really well with a flashlight and poked around a bit for loose connections. I found two which I would have not of found without a flashlight. I tried plugging the amp in again, but I am too scared to wait for something to smoke. I noticed that I didn't hear a sparkle from the rectifier tube which is good news. The power resistor gets very hott to the touch after 10 seconds or so. Should I try a higher watt resistor? Thanks again for your time.
Old 12th August 2005, 12:33 AM   #8
Account Disabled
I painted the transformers with Rustoloem Black Satin Spray Paint. The insulation looks alright to me. No more sparks from the tubes, but the power resistor still smokes alittle bit. Is it just because the resistor has gone bad? I also can't find the resistor's value which is 350 ohm should I go lower and get the 330 ohm or the the 390 ohm? Thanks for your time in this matter, Kevin.
Old 12th August 2005, 02:11 AM   #9
karma's Avatar
what was loose? if you got a variac use it. bring it up slowly or u may risk loosing more parts.
if you can get a Schematic for is amp and double chech everything
does this resistor smoke right away?
Old 12th August 2005, 02:15 AM   #10
A 10 watt resistor is going to get hot, but it shouldn't smoke unless you painted it too. Grab a voltage measurement across the resistor and figure your current followed by power.
I couldn't function at my bench w/o my lighted magnifying glass.
Turning a power resistor into a power amp (sorta) N-Brock Chip Amps 25 7th October 2009 05:10 AM
Smoking Resistor? 65blkbkgt Car Audio 14 3rd January 2009 03:55 AM
Power Amp P.S. Bleeder Resistor Reg? fastcat95 Solid State 2 28th April 2008 05:10 AM
Resistor power rating for XO? JC Fardo Parts 4 16th December 2004 07:52 PM
Page generated in 0.10394 seconds (77.29% PHP - 22.71% MySQL) with 11 queries
