How long does a 7199 last?
Old 10th August 2005, 07:45 AM   #1
gnugear is offline gnugear  United States
Default How long does a 7199 last?
Does it wear like a normal preamp tube or is it the kind that lasts forever (figuratively speaking).
Old 10th August 2005, 08:36 AM   #2
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
If you leave it in the box, it will last very well. (Unless there's a faulty seal at the pins.)
Seriously, this is like asking, "How long is a piece of string?" In my experience, if you operate a valve at 1/3 of full dissipation it lasts so long that you don't get to find out its lifetime.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 10th August 2005, 06:16 PM   #3
amperex is offline amperex  United States
Default I can do better.......
If operated within recommended parameters, about 5000 to 7500 hours for quality NOS.
Old 11th August 2005, 06:45 AM   #4
Thanks ...
How long does a 7199 last?Hide this!Advertise here!
ECF80 instead of 7199 richwalters Tubes / Valves 28 16th July 2013 04:49 AM
7199 RCA AND GE tubes Burnedfingers Swap Meet 2 19th May 2009 11:02 AM
Forgot to do this long long time ago chris ma Introductions 2 30th October 2003 10:53 PM
Long output lead or long output transistors leads? which one to pick? chris ma Everything Else 3 6th June 2003 12:06 PM
7199 glowing purple? GLF Tubes / Valves 10 17th February 2003 11:08 PM
Copyright ©1999-2017 diyAudio
