diyAudio Sponsor
Old 8th August 2005, 03:42 PM   #1
karma is offline karma  Canada
karma's Avatar
Default bogen db20 Schematic
ill likelly never find one. anyone have a idea ware i can get one?
thanks.
Old 10th August 2005, 07:39 AM   #2
MikeR is offline MikeR  United States
Karma,
I have one that I will send you by e-mail. Too big to post.
Old 10th August 2005, 09:47 AM   #3
karma's Avatar
ok thanks
karma1968@rogers.com
Old 17th August 2005, 08:59 PM   #4
karma's Avatar
yes thanks to the schmematic one of two is finished. that would be the blue one. wow it sounds great.
thanks.
Old 17th August 2005, 10:04 PM   #5
how bout for a bogen db110?
I have two working ones, but I would like to go over the circuit and tracing it out is a PITA.
much appreciated if anyone has it available.
Old 18th August 2005, 01:04 AM   #6
Tom Bavis's Avatar
Email for the DB110 - tbavis(at)rochester(dot)rr(dot)com
Old 24th August 2005, 10:44 AM   #7
karma's Avatar
pulled a all nighter and fixed the second one. i have my tester tubes on it now just in case somthing goes bad. so far so good
all caps replaced. i recaped them from the under side and left the old ones for looks and value
im sending the preamp tube covers in to be Rechromed should look nice.
Old 25th August 2005, 02:55 AM   #8
looks nice karma. sounding the same?
tom, I emailed you about the db110 schematic. Maybe you filtered it out or something. I would like a copy if you have it available. Just a quick look at a couple things...otherwise I can order one from reprinters I guess. (this forum has no PM, it seems).
Or if someone else has one.. mail psilocybe@mail.com
edit (email formatting.. spammed address anyway)
Old 25th August 2005, 03:52 AM   #9
karma's Avatar
sounds the same the old main caps where 8uf 500v the ones i had where 500uf 500v and im not happy with em so i ordered new ones
http://thetubestore.com/ca-lc-32uf-500v.html
Old 25th August 2005, 01:49 PM   #10
kmtang is offline kmtang  Canada
kmtang's Avatar
Hi Karma,
Why don't you try the new TubeCap from Mundorf? They are really good.
Johnny
Bogen V20 PA Amp Schematic or ? MetalBay0_1 Tubes / Valves 5 26th November 2008 09:41 PM
Bogen L60 schematic blindbrett Tubes / Valves 2 16th January 2008 10:41 AM
set of 4 working bogen db20 tube amplifiers karma Swap Meet 5 6th June 2007 07:38 PM
one mono bogen db20 karma Swap Meet 2 18th September 2006 08:07 AM
Bogen amp schematic 9am53 Tubes / Valves 6 20th February 2005 08:23 PM
Page generated in 0.15273 seconds (56.56% PHP - 43.44% MySQL) with 11 queries
