diyAudio Sponsor
Old 7th August 2005, 02:09 PM   #1
Default update to phillips sepp otl?
Here is an attached schematic of an older Phillips SRPP OTL amplifier meant for 800 ohms.
If I substituted 6AS7s or 6C33C's what kind of power output per tube pair is expected?
Is there anything I should be aware of?
Or should I use EL509's?
Finally, do a balanced config to cut out that output coupling cap?
Anyways... its either this or a SE OTL amplifier...
It is not you... you are it.
Old 7th August 2005, 02:35 PM   #2
Default this is interesting
check this out:
http://www.super-otl-audio.com/Description.htm
Old 7th August 2005, 03:23 PM   #3
The Philips circuit has a lot of disadvantages; low output power and only class A is possible it is basically just a SRPP.
In my first OTL that I built more than 30 years ago I used that circuit and it works and sound quite good but there are much better circuits available, see here http://www.tubetvr.com/otl.html
Regards Hans
Anyone out there try a SEPP OTL guitar amp?? aletheian Tubes / Valves 10 14th October 2005 03:05 AM
Sepp? Tim Wyatt Tubes / Valves 4 27th April 2005 06:34 AM
SEPP design any exposure? Glass_painter Tubes / Valves 1 14th May 2003 11:45 AM
SEPP for philips 800 ohm loudspeaker Aiace Tubes / Valves 3 10th February 2003 07:20 PM
Page generated in 0.87591 seconds (6.36% PHP - 93.64% MySQL) with 11 queries
