| diyAudio Sponsor | ||
#11 | |
Banned
Thanks so much for this tube.lib files I have been looking for some.. Do you got any more to share.. ? j' |
#12 |
Tubelab, thanks a lot for the library, that was just what I needed
/U. |
#13 |
At this point you have my entire tube collection, even though the library is small, it contains everything needed to build amplifier boards. All of my other libraries were from my digital design days using socketed dip and PLCC parts. Since there are far better parts in the current Eagle libraries, I don't even use them any more.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#14 |
Thanks for the link to the library containing the 7 pin part. I am planning a SE amp design that uses 6AQ5 tubes. I will modify this part instead of starting over if it works out.
#15 |
And for Proteus? Anybody have a Library for it?
Best Regards, Felipe Navarro
Brazilian Tube Amp Builder. |
#16 |
Hello,
Does someone has the library for tubes in Eagle whitch contains the ECC85 ?? Its kinda urgent please Thanx |
#17 |
I was about to help you ... right up until the "kinda urgent" part. How about doing your own homework ? You couldn't even be bothered to look it up so why should we help you ? Oh, I nearly forgot, because it's "kinda urgent" ...
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it." |
#18 |
thanks for release the file was very useful.
| Tube sockets | 56oval | Tubes / Valves | 11 | 11th July 2008 11:01 AM |
| tube sockets | bigpanda | Tubes / Valves | 1 | 15th June 2006 09:34 PM |
| Looking for tube sockets | satelitis | Tubes / Valves | 0 | 8th May 2006 01:08 PM |
| Tube Sockets | FrankRoss | Tubes / Valves | 4 | 19th March 2004 10:48 PM |
| Tube sockets with the same pin spacing as the tube | Andypairo | Tubes / Valves | 5 | 15th March 2004 01:08 AM |
| Page generated in 0.16484 seconds (51.29% PHP - 48.71% MySQL) with 11 queries |
