diyAudio Sponsor
Old 4th August 2005, 05:03 PM   #1
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Default ralph power pp amp with 807 ?
http://www.meta-gizmo.com/Tri/interstage.html
What do I have to change in this design to be able to use my 807 tubes who are patiently waiting ?
thanx in advance
jh
Old 4th August 2005, 05:51 PM   #2
Miles Prower's Avatar
Depends on how you want to run the 807s: pentode, ultra-linear, or triode. You will almost certainly need to change the output xfmr, and possibly that interstage xfmr.
The PS will likely need to be modified for different DC out, plus V(sgsg) if you use pentode mode.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 4th August 2005, 06:06 PM   #3
Jaap's Avatar
Default I am thinking triode
Old 4th August 2005, 10:00 PM   #4
Here ya go: 807 App Notes. This is quite the comprehensive information on that. Includes both RF and AF operating modes, and plenty of data for pentode/triode operation at various DC voltages, Q-Point bias, and data on estimated THD for each.
www.dolphin-hsl.com
Old 4th August 2005, 10:46 PM   #5
amperex is offline amperex  United States
Page wont open to review schematic.................
Old 5th August 2005, 02:17 AM   #6
Brett's Avatar
No trouble here, but here's the drawing anyway.
Old 5th August 2005, 02:18 AM   #7
Brett's Avatar
And PSU......
Built this and similar. Good little circuit.
Old 5th August 2005, 11:20 PM   #8
PRR is offline PRR  United States
PRR's Avatar
How old-fashioned.
807 is nothing but an ugly 6L6. You will have to separate the heater from cathode function: study any normal indirect-heat output stage. Triode-strap it with a 100 ohm resistor G2 to Plate. Adjust the cathode resistor (shown in the power supply section) to an appropriate value for 807/6L6 and the supply voltage you like. 300 ohms may be a good trial value for 275V supply.
The intent seems to be to run Triode. Or at least I would try that first.
There are not a lot of interstage transformers on today's market, the Lundahl will be fine. It may be "too good" in that the 807/6L6 can be driven with less voltage swing than 2A3/6B4, but there isn't a smaller model. The load is the same: two naked grids. Overall gain will be a couple dB higher: no big deal. Input overload voltage will be a little less, but I assume there is a Volume control somewhere up-river.
The output transformer is only specified as "Sansui 1000A". I'm guessing that it is the usual 5K or 8K winding, which is appropriate for self-biased 807/6L6 also. Triodes are not that fussy about load.
2A3/6B4 will make a little less power than 807/6L6 working with the same supply and load impedance, due to higher plate resistance. This may be several dB different, not a lot.
Old 5th August 2005, 11:31 PM   #9
Jaap's Avatar
Default 807
PRR, thanks for your input.
I am thinking about the 807 because i have some lying in the cellar. I have the impression that this tube has a good reputation.
I suspect that you have some ideas of bettering the circuit in a more modern fashion or that you have suggestions for a better output tube. I have the Lundahl LL1660 in mind as interstage transformer.
Feel free to share your ideas with a not so experienced tubenut.
regards,
JH
Old 6th August 2005, 12:13 AM   #10
PRR's Avatar
Oh, No!
"Old fashioned" is not bad. Many of the Old Ways are still the best. I think it is a fine amp.
My only "change" would be to suggest using the 2A3/6B4 instead of the 807/6L6. But if you have a cellar full of 807, they will certainly work well.
If you are power-hungry, you can raise B+ on 807 toward 400V. Use the suggested conditions in the 807 app-note that Miles showed us.
40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? dtm1962 Solid State 10 15th September 2011 08:38 PM
Ralph from Atma-sphere will be giving a talk 09/16 Zero Cool Tubes / Valves 2 16th September 2008 07:54 PM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 06:49 PM
Ralph Power amplifier stigla Tubes / Valves 68 15th December 2002 08:33 AM
Page generated in 0.13266 seconds (73.02% PHP - 26.98% MySQL) with 11 queries
