diyAudio Sponsor
Old 6th August 2005, 08:29 AM   #11
Tubes4e4's Avatar
Hi PRR,
807 is nothing but an ugly 6L6.
Ugly?
Look here :-)
Tom
If in doubt, just measure.
Old 7th August 2005, 10:27 PM   #12
Miles Prower's Avatar
No it isn't. The 6L6 is a whimpier version, the 807 being an RF type, having greater P(D) and P(SG) ratings than the 6L6 (25W/19W; 3.5W/2.5W) and a higher voltage rating (750/360). Even though it's an RF type, the 807 has better THD specs than the 6L6. If you don't push them real hard, 807's can give THD figures below 1.0%, whereas the 6L6 doesn't even come close, never going below 2.0%.
This is probably due to the 6L6's being more of a "consumer electronics" device operated at lower voltages, higher currents, and lower impedances (cheaper iron all the way around) than is the case where 807's are used. Even though both types can do 26.5W in class AB(1), I'll take the extra 6.0W margin and lower THD.
There are no foxes in atheistholes
www.dolphin-hsl.com
40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? dtm1962 Solid State 10 15th September 2011 07:38 PM
Ralph from Atma-sphere will be giving a talk 09/16 Zero Cool Tubes / Valves 2 16th September 2008 06:54 PM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 05:49 PM
Ralph Power amplifier stigla Tubes / Valves 68 15th December 2002 07:33 AM
Page generated in 0.08687 seconds (63.88% PHP - 36.12% MySQL) with 11 queries
