| diyAudio Sponsor | ||
Dear all,
I'm looking for the the captioned schematic. Actually, I stored in my PC but I can't find it ![]() Pls help.
Bee696 |
#2 |
hi,
if you know what format it is, example, .jpg. then you can use the "search" function in your pc. if its there you will find it.
http://www.electronicslab.ph/forum/i...?topic=32688.0 |
#4 |
#5 |
#6 |
These are variations on the tried-and-true Maida design, which I've used successfully many times in the past - all the way up to 1000V! The problem has always been that high-voltage bipolar transistors have low current gain, so you are forced in many cases to use a Darlington configuration. A buddy of mine just built a Maida variation using a 1000V MOSFET (in a TO-220 package) to stretch the voltage, instead of a Darlington pair. Works great he says. I don't have the part number but I can ask if anyone wants to know. There are surely a large number of high voltage MOSFET types available.
Brian |
#7 |
Hello. For a MOS-FET version, check the following site of my friend.
http://www.geocities.jp/shoranosekai...irozu2of2.html The original design was introduced by Mr. Kato (JA9TTT). His site no more carries the drawings. I have followed his design and enjoy verious kinds of high voltage power supplies for my tube amplifiers. |
#8 |
Check out the captioned SFM80 Schematic here:
http://www.diyparadiso.com/proj/sfm75.htm Don't worry about his SRPP comment at the top of the schematic, not a SRPP in sight. The whole front end circuit is available as a kit or PCB only from Curcio Audio Engineering (CAE). IIRC the PCB-1A. Of course, no circuit value on the schematic at CAEs website. I've built a few of these - works well. Cheers, Ian |
#9 |
Dear all, Thanks so much for your helps!
Bee696 |
#10 |
Dear all,
Actually, I stored in my home 3 boards for sale. If somebody need a board i can sale them. my mail walter_burkhardt@web.de regards walter |
| High Voltage Regulator | mod_evil | Power Supplies | 36 | 28th October 2011 12:48 PM |
| High voltage, high current super regulator, possible group buy | peranders | Group Buys | 54 | 2nd June 2009 09:43 AM |
| High Voltage regulator PS | maxpou | Power Supplies | 1 | 29th April 2006 07:14 PM |
| TIP50 voltage regulator | jj2 | Tubes / Valves | 16 | 22nd April 2006 05:10 PM |
| Page generated in 0.10979 seconds (70.95% PHP - 29.05% MySQL) with 11 queries |
