diyAudio Sponsor
Old 2nd August 2005, 10:03 AM   #1
Default My experience building a DRD d3A/300B amp
Hello all,
This my first post on this forum, although I’ve been a long time reader here.
First of all I would like to thank to everybody that contributes to these forums. I still find that is amazing to be able to have a direct window to such variety of views, thoughts and ideas. I would specially like to thank Thorsten, who took the time and patience to privately guide me on the design of the amplifier that I’d like to present here. I know that he can get on the nerves of some people but I think that he just tries to spoil people to do their homework. He is an opinionated fellow and he sometimes like to present his knowledge in a mysterious and challenging manner but the wealth of info that he has shared with dummies like myself here is been of great help and the dude deserves my respect.
First a little background. I’m a classical musician. I got my Master in performance at USC in Los Angeles before coming back to Barcelona, were I teach and perform. As a musician I’ve been lucky enough to play with some great groups, like the LA Phil, for some great conductors and also in some nice places, like a few years playing at the Aspen Music Festival.
The first time I heard a tube amp was at the house of a Japanese student whose husband worked for Nakamichi in LA. It was somehow like love at first sight. I had no electronics background whatsoever…quite the opposite indeed but ever since then I started to read and read trying hard to understand the most I can, although I have to say that the wealth of info is sometimes overwhelming for someone like me. Still it’s pretty amazing what one can learn here and there.
After listening to some friends systems and from I gather in the forums, I started to have a pretty good idea of what would be the reproducing system that I would like to build myself.
To make a long story short and after a few small “experiments” I decided to build my first serious amp. It was going to be a 300B. Never heard one before but there would have to be something about it after all the buzz that there is around. For a moment I though of going with a kit like the Welborne DRD or the Lady day, which I’m sure it would have been much easier in terms of planning, building and parts collecting…but I decided to build it from scratch. What the hell, I though, do it ALL yourself.
As I said before, I got in touch with Thorsten who very patiently helped me out to adjust the values of his original 437a/300B DRD amp to use a d3A tube in the input stage instead. After a few months of parts collecting and finding the right time to build the this, it was finally done.
The chassis is pretty big, really oversized. I didn’t want to have layout problems. The aluminum top plates are from Schaeffer in Germany. All resistors on the amp side are Dale, except the 47k input resistor an the 60R4 grid stopper which are Caddocks and the 100R potentiometer which is a Vishay. I might change the grid stopper with a carbon type like a Kiwame or Riken soon. The capacitors on the B+ are Ducati motor-run. Yeap, I can brag about that with my motorcycling friends…electrolytic on the filament supply are Panasonic low ESR. I used Lundahl iron everywhere except the power transformers. I also got a pair of filament chokes from Jack Elliano, one of the guys that brought this type of design to the forefront. Wiring is 26AWG fine silver from Percy audio on Teflon sleeve. Ground bus is 12AWG silver. Input jack and speaker post are Neutrik. Tubes are Full Music 300B and 274A both “mesh” types. d3A are Siemens.
I have to say that due to my limited knowledge of electronics I had a TV repair man friend of mine help me out with the building and testing of these amps. A good idea if you’re are a newbie dealing with potentially deadly voltages.
The Volume control is a pair of copper TX-102s and the speakers were first a pair of Supravox signature bicones that were later upgraded to the field-coil 215-2000 adapted for open baffle.
Sources will need to be upgraded but for now they are primarily a MOTU 896 firewire interface that plays EAC extracted Ape or Flac files from the hard drive of my computer. Vinyl is played trough a Rega P3 with a Denon DL103R and a crappy phono box riaa stage.
Now for the sound of this thing. I mostly hear Jazz and Classical together with some 60s and 70s pop once in a while. A musician I sometimes find hard to believe how some people is so damn “accurate” while describing the sound of this and that component, specially giving the fact that there are sooooo many variables that could influence on the overall sound of a given system, starting with the quality of the recording itself. Well, this amp sound great, really amazing. Trust me guys, I heard not many other amps but enough to know that this is really a special design. First of all there is almost no noise coming out the speakers. Then, when the sound starts happening you always have the impression that you are hearing something that is VERY close to the original; for good and for bad. Awful recording are almost unbearable to hear…a pity because I have to really concentrate on the performance in order to not get distracted by the sound. Why is that? Because the amps sounds so amazing when you feed them well recorded material that it makes the bad recorded stuff look really bad.
I also make my own recordings of my students and myself. Last one was made on a pair of Schoeps mics on a very spacious venue. Mastering the recording on the Supravox and the 300Bs is just a pleasure. Really pretty close to what it sounded like there. For me personally there is no better proof of worthiness. I’m obviously quite proud of these babies, specially considering that less than a couple years ago I didn’t even know what a capacitor was.
Future holds a new house that hopefully will be finished in March. I will finally have a decent space to listen to my system (right now I have it on my rather small living-room) I will then probably upgrade my analog rig to a Teres turntable. I’m also looking forward to build Steve Bench’s no C phono stage and I will probably have to add a set of open baffle subwoofers to go with the Supravox…but that will probably have to be covered on a different post.
I’m sure that the amps could probably be improved and so you know, I’m totally open to any kind of suggestions.
Thanks again to everyone and I hope that my experience serves a motivation to all of you undecided adventurers that are afraid of trying. Go for it! Is really worth it.
Best regards,
Luis Gascón.
Old 2nd August 2005, 10:08 AM   #2
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Gracias! Great first post...a pleasure to read.
Any pictures and/or schematic?
Bas
Old 2nd August 2005, 11:36 AM   #3
Default Outside
Yes here they are, I tried the first time around but I didn´t get to do it right...
Old 2nd August 2005, 11:38 AM   #4
Default Inside
Old 2nd August 2005, 11:43 AM   #5
Default Amp Schematic
Old 2nd August 2005, 11:46 AM   #6
Default Power supply Schematic
Old 2nd August 2005, 12:38 PM   #7
Did you use the AM versions straight away? Or did you upgrade to them later?
Old 2nd August 2005, 12:52 PM   #8
Gluca is offline Gluca  Italy
tarmac ripper
Gluca's Avatar
ohh nice ... I like these wood/brass cabinets. And I like DRD as well, a very clever idea. I have read lots of positive reports on that topology and I would love listening to them.
From the schematics I see you did use the AM OPTs from Lundahl ... somewhere here on diyaudio a Jap guy (or was it somewhere else??) was saying that permalloy Tamura/Tango are way better than LL. An other great pick up would be a MQ iron. They are not exactly that cheap btw.
Gianluca
Old 2nd August 2005, 01:14 PM   #9
tarmac ripper
Gluca's Avatar
nice PSU. And what about a DC current regulated heater?
Old 2nd August 2005, 01:26 PM   #10
Hi Luis,
Would there be any chance of buying a cd or two from you? I would be interested in stuff that is not overprocessed and mastered by a musician himself.
Bas
Anybody have experience building an OTL amp? jduffy Tubes / Valves 8 6th February 2007 05:46 PM
Newbie building d3A DRD 300B stefanolo Tubes / Valves 8 3rd February 2007 03:51 PM
Building a Sun Audio sv 300b Mk II clone doug_olitsky Tubes / Valves 6 25th December 2004 01:39 AM
My gainclone building experience (updated as I go along) elizard Chip Amps 14 11th May 2003 08:21 PM
Interesting amp building experience... BANG! SHiFTY Solid State 8 3rd April 2003 09:47 PM
Page generated in 0.12718 seconds (84.13% PHP - 15.87% MySQL) with 11 queries
