| diyAudio Sponsor | ||
Has anyone built one of Andreas Ciuffoli's OTL amplifiers (ver.8.2) and can help me with the value of the coupling capacitors to the 6c33c's. Can't make out if they are 2.2 or 22uf. Many thanks, David. |
#2 |
If you want people to respond, you need to add a link to the diagram...
Oh, and welcome to the forum!
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#3 |
Thanks for that - have attached link (I hope!) problem is I can't tell from this diagram which value to use - 22uf seems a little excessive (but may be correct) Someone who's built one might know what works perhaps?
#4 |
2u2 seems like a very sensible value to feed 68k grid leak resistors...
#5 |
Yes I agree - Thanks. Makes sense to me too.
#6 |
It seems that power supply filter capacitors are a bummer high also! Is it? 4700uF charged at 150V are a bit explosive, are they?
And ... and... are you shure this is not a fake? Italians are used to play jokes any time! And when they are not, they exagerate a bit!
Nothing happens by itself, you have to work hard to arrange things to make it happen. |
#7 |
Yes I agree with that as well! Have some 2200uf 350v which I'll be using. Probably alter the PSU a bit. Did you notice the Xfrmr is rated at 4A? Looks as if the PSU is well overrated generally. Still, amp. cct looks interesting.
#8 | |
2200uF is barely enough to keep hum on the output low enough in this design, the output stage is not completely symmetrical with regard to power supply rejection so you need quite good filtering to reduce hum to acceptable levels. In a later version Andrea used a CLC filter for the anode supply which is an idea. In my OTL which has a similar output stage I use good quality elytics of totally 5500uF without chokes with very good result, the quality of the elytics especially ESR is more important than the cap value itself. Quote:
Regards Hans |
#9 |
Thanks for the info. I should have said my intention is to use a CRC filer per rail using two 2200uf capacitors. Would you approve? I have checked the ESR and is around 0.05 Ohms.
This is my first attempt at OTL so any help/observations is most welcome. David. |
#10 |
Bah. People cought using a resistor for filtering a power output stage should be shot.
It's class A anyway, which...is pretty pitiful, adding insult to injury as it's already a tube OTL to begin with. So I guess it doesn't really matter. Whatever. Good rule of thumb: 2mF (2000uF) per ampere. A bit less at high voltage since more ripple can usually be tolerated (percentage-wise). As-is, if it needs as much filtering as claimed, I don't really have a problem with 4700uF, but 2 x 1000uF would be a lot better, particularly with 100mH between them. Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
| Page generated in 0.17909 seconds (40.90% PHP - 59.10% MySQL) with 10 queries |
