best material for mounting tubes sideways
Old 25th July 2005, 05:36 PM   #1
karma is offline karma  Canada
karma's Avatar
Default best material for mounting tubes sideways
what would be the best material for mounting tubes sideways?
thank's
Old 25th July 2005, 10:29 PM   #2
gingertube is offline gingertube  Australia
Look in your local phone book for Aluminium supplier and then visit their sales office - they often have a bin of off cuts of various angle sections and H sections at very reasonable cost. The angle sections would be ideal for this job.
I visit my local supplier about once every month or so jusy to grab whatever useful off cuts are in the bin.
Ian
Old 26th July 2005, 05:11 AM   #3
On Hiatus
SY's Avatar
This is an ideal place to use perfed aluminum, if you can find someone to bend it. The usual difficulty with side-mounting is ventilation, and perfed material can be a useful aid.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 27th July 2005, 04:26 PM   #4
kmj is offline kmj  Sweden
kmj's Avatar
a piece of aluminum and a "angled" piece of metal works fine.
Ok, everything looked fine untill i started to add the wires to ground (my first p2p-work)
Old 27th July 2005, 04:57 PM   #5
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Please tell me that the heater wiring isn't that red/black twisted pair that goes straight through the audio wiring.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 28th July 2005, 11:09 AM   #6
On Hiatus
SY's Avatar
If I count pins correctly, they are going to 4 and 5, so...
Old 28th July 2005, 04:10 PM   #7
cyclotronguy is offline cyclotronguy  United States
Many tubes do not like to be mounted sideways. Vertical up or vertical down is fine.
Cyclotronguy
Old 28th July 2005, 06:06 PM   #8
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Default Sideways tubes
It is true that some tubes do not like being mounted sideways. The small signal types shown in the picture are fine. In general most indirectly heated tubes can be mounted in any position. Directly heated tubes like the 300B, 2A3, and 45, do not like this. Operating these tubes on their side will cause the filament to sag when it gets hot, shortening its life. In extreme cases it can touch the grid leading to all sorts of unplesant things. Mercury vapor rectifiers don't like being on their side either. The data sheet for each individual tube type (found in a tube manual, or on the net) will usually explain the allowable mounting positions.
I have found that some extruded aluminum scrap from a construction crew that finishes out the interiors of office buildings is quite useful for mounting tube sockets. It punches well with a Greenlee punch. It also makes good heat sinks for power transistors up to about 15 watts dissipation. This stuff is normally used as the top cap for short interior walls.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 28th July 2005, 06:09 PM   #9
kmj's Avatar
eeehh, yes it is. And thats probably why i get a strange high-pitch pulsing sound when i turn it on.
But how the h**l can one keep the wires away when you have to get the tubes heated?
Old 28th July 2005, 06:23 PM   #10
EC8010's Avatar
Heater wiring goes in first and is best done with solid core wire (stays in place better). It doesn't need to be very thick for small-signal valves, so it's easy to push it into the corners of the chassis. It should never float in the open air.
However, I doubt that your "strange high-pitch pulsing sound" is due to heater wiring. It's more likely to be due to a wire (or component) from the output going near to an input wire.
best material for mounting tubes sidewaysHide this!Advertise here!
Sideways Dipole Bass sdclc126 Multi-Way 27 27th May 2013 05:47 PM
Russian tubes - what pin material? GlidingDutchman Tubes / Valves 8 14th July 2008 12:35 PM
Help with horizontal mounting of 01-A and VR tubes arnoldc Tubes / Valves 2 14th March 2007 11:32 PM
mounting tubes upside-down Mr. Triatic Tubes / Valves 18 9th August 2004 04:44 AM
Q: Can an air conditioner be installed sideways? multiplexor The Lounge 16 26th August 2003 03:19 PM
Copyright ©1999-2017 diyAudio
