diyAudio Sponsor
Old 22nd July 2005, 01:08 PM   #1
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Default Your favourite filament supply for DHT's?
I have a Ba tube for a customer that is still getting far too much noise in via the filaments. Right now I have a LM317 as voltage reg followed by a current reg LM317...but there is still a huge amount of noise coming in through there. Diodes are Schottkey's.
Common mode filter after the regs the solution? With some 2200uF caps after the common mode filter?..
I know I'll get them silent...but was curious about how you guys solved it.
Old 22nd July 2005, 01:35 PM   #2
bigbulb is offline bigbulb  Canada
May I know what tube you are using? If 2A3 even AC filaments should be no problem.
My 2A3 running AC filaments and noise level across 8 ohm load is 2.8mV RMS, should be good enough.
BigBulb
Old 22nd July 2005, 01:36 PM   #3
Hi Bigbulb,
Ba tube in preamplifier type setup.
Bas
Old 22nd July 2005, 02:05 PM   #4
kmtang is offline kmtang  Canada
kmtang's Avatar
Hi Bas,
How is the schematic looks like for the preamp and PS?
Johnny
Old 22nd July 2005, 02:10 PM   #5
Hi Johnny,
Here's the schematic of the psu
http://www.triodedick.com/cleo_5/cleo_voeding_gif.GIF
And here for the preamp...
http://www.triodedick.com/cleo_5/cle...terker_gif.GIF
Bas
Old 23rd July 2005, 12:14 AM   #6
Send a message via Skype™ to etalon90
Assuming that you have a perfect HV supply (with very few mV ripple)
I`ll try a switching power supply desing for computer.
You can found 5V@1.5A and 12V@2A for less that $5...
I use it myself and feed a RC circuit to provide the exact voltage on my hum free #26 preamplifier.
And for the C, I use only a small 150Uf elna cerafine...
Of cource, common mode choke on the main to isolate the SPSU is a must because they might produce noise in your HV supply and get the sound worse... (I use an isolation transformer + some 0.1Uf)
give-it a try.
I can't understand it. I can't even understand the people who can understand it.
- Queen Juliana
Old 23rd July 2005, 12:25 AM   #7
Thanks for the tip..but aren't these units huge? And only part of a complete computer psu?
Bas
Old 23rd July 2005, 12:28 AM   #8
By the way...how can I get detailed photo's from your yahoo photo's? I know in the uk version you can click on a button to download the original high quality version..I am interested in your 10 amp.
Old 23rd July 2005, 01:25 AM   #9
agent.5 is offline agent.5  United States
Maybe you can tried ultrasonic heating. The transformer costs $15 on Ebay. Here are some threads:
http://db.audioasylum.com/cgi/search...&forum=tubediy
Old 23rd July 2005, 03:46 AM   #10
Miles Prower's Avatar
You don't have a filament hum problem, you have an instability in your regulators. These IC voltage regulators have internal frequency compensation, however, it only works if you connect 22uF (tantalum) -- 100uF (aluminum) across the outputs. The 100nF capacitors the schematic shows are too small. One or both are oscillating and feeding that signal into the tube via the cathode.
There are no foxes in atheistholes
www.dolphin-hsl.com
K-502 Filament supply (or K-12M) jmillerdoc Tubes / Valves 6 18th November 2009 12:59 AM
Yet another DHT filament supply astouffer Tubes / Valves 25 5th July 2009 11:08 PM
Parallel vs. series filament supply - or another filament idea engels Tubes / Valves 11 13th May 2007 01:06 PM
DC filament supply LC or CL TBM Tubes / Valves 1 7th August 2005 07:26 PM
When using a DC filament supply on a DHT... Saurav Tubes / Valves 31 18th September 2003 05:03 AM
Page generated in 0.14621 seconds (60.95% PHP - 39.05% MySQL) with 11 queries
