diyAudio Sponsor
Old 22nd July 2005, 07:42 AM   #1
Default Quantum Impex
Can anyone provide any information on a Quantum Impex Minstrel tube amp? I have tried google but found nothing. Any help much appreciated.
Old 31st January 2006, 09:01 PM   #2
morst is offline morst  United States
morst's Avatar
I have a Quantum Minstel.
It is a hybrid integrated tube amp. The input stage is all mosfet electronics, and the output is push-pull tubes with large transformers. It came rated at 20wpc with 6L6 output tubes, but it can run at 40 wpc using EL34's. That would change the sound somewhat, but it's made to do it, or to use the milspec tubes, I forget the number but they are el34 compatible. .
If I recall correctly, the EL34 puts out 34 watts per channel with very low harmonic distortion, but since you can run tube amps with a lot more distortion "by the numbers" it will sound good up to 40 watts.
I think I bought mine in 1996, in St Louis MO from Flip's, and they had a stack of them. . . after hearing mine, 4 of my friends all bought them too. One had a cracked circuit board from being dropped but it was repaired. As far as I know, all 5 we bought are still in daily use.
Original retail price in 1996 was $1800.
Old 31st January 2006, 09:54 PM   #3
Many thanks for the information Morst, I was starting to think I was the only person who had one of these excellent amps. I run mine through Lowthers or TDL studio2 transmission line speakers and it sounds superb through either. Mine has EL34's , but I may try changing for the 6L6 tubes you suggest. You dont have any info on the bias adjustment by any chance do you?
Old 1st February 2006, 06:47 AM   #4
morst's Avatar
OK, I found some of the documentation. (I still need to find my glossy sales sheet) A very kind friend of mine gave me a matched quad of 6L6's for a "HOUSEWARMING" gift when I moved recently, and he included the data sheet for the amp. He marked it up a bit but I will scan it and make it available to those who wish to know. (splodgedog, I'll email it to you as soon as it's scanned.)
My friend specified that although the amp will work with other valves, the 6L6GC is the only one we should use.
Old 1st February 2006, 10:33 PM   #5
Got the Manual, many thanks Morst.
Old 22nd January 2008, 09:49 PM   #6
I have one of these tube integrated amps less the tubes and hope to find biasing instructions. Found this site just now via Google and as a new member can't e-mail the two guys who chatted about it long ago.
If either of you are still here or anyone else knows, I'd really appreciate the input. It looks like the manufacturer is long out of business.
Old 28th January 2008, 06:16 PM   #7
morst's Avatar
Let me try to attach the scan here, so anyone who needs it can find it. .
(good thing I have this board set to email me when there is a reply to the thread!)
Ok let's try posting it on imageshack.us.. .
note my friend's instructions in pen, we were told that milspec 5881 tubes could be used, but we're not sure if the biasing would be the same. Note that use of the 5881 tubes will increase the power output to approx 40w/ch and will change the charactaristic sound of the power stage compared to 6L6 tubes.
Old 29th July 2010, 04:17 PM   #8
Hi - hope you are still getting alerts re the Minstrel amp - I have two of these - one with partridge transformers and another which I bought yesterday - I chose these over class A valve amps such as the puresound A30 and the quad II as they are a bit more punchy but still very much more open than solid state amps - but I know next to nothing about them and neither does my hifi delaer - one says "made in scotland" and the other "made in great britain". I tried to open your documents but no joy - any chance of you reloading them as jpegs ? Thanks
Quantum tunneling volume control and resistors albin Solid State 96 15th October 2011 03:29 PM
Bybee Quantum Purifier Experience. mrfeedback Everything Else 321 27th August 2010 09:41 PM
Quantum 102 Pre-Amplifier rocky99 Solid State 0 14th January 2008 07:30 PM
Topological quantum computer Nixie Everything Else 0 24th April 2006 10:57 PM
Quantum QRS schematics schoko Instruments and Amps 0 1st August 2004 08:32 PM
Page generated in 0.11889 seconds (64.73% PHP - 35.27% MySQL) with 10 queries
